What year 900rr brake bracket with 900rr swingarm brace?
For those of you who have installed a 900rr swingarm brace: what year 900rr rear brake caliper bracket is needed to relocate the caliper?
Also: is a 929 or 954 brake bracket usable?
Thanks!
James
Thanks!
James
whenever you put on a 900rr brace,you have to use the 900rr rear brake bracket.
this puts the rear brake at a different postion to clear the brace.
but to put on the rear bracket,you need to weld on a new block to the swingarm that the bracket slides into for the correct postion.
so from the 900rr swingarm,you need
brace
rear brake bracket
small block attached to the swingarm
than you go to go with the project.
brace
rear brake bracket
the small block may not be needed,but i remember something about it has to be moved to a different position.
here is a link that might give you some help.
https://www.superhawkforum.com/forum...-advice-25292/
Shawn Torpey
02-04-2011 09:44 AM
Mike996
11-05-2009 07:43 AM
