Whar size is the socket to remove clutch basket?
Yes it is a 30 mm
had a hard time finding a 30mm 12 point but that is what it took. BTW you do not need a holding tool to torque the nut. Just put it in gear and slide a 2x2 piece of wood under the swing arm thru the wheel and under the swing arm on the other side. The bike is not going anywhere and you can make the 94 ft/lbs of torque.
jibbs
10-14-2011 03:44 PM
