vtr oil eather
Old 08-30-2009 | 02:21 AM
merlyn's Avatar
merlyn is on a distinguished road
vtr oil eather
Hy! I change the oil every 5000 km! When I ve changed last time the level was over upper a bit, why the oil level is about to minimum after approx 5000 km? the oil I use is motul 300v double ester 10 w 40! I want to mention that my bike has only 35000 km! What is the problem???
Old 08-30-2009 | 06:49 AM
gboezio's Avatar
It could be many things, dripping out, burnt trough cranckcase breathers (oil in airbox), trough valve seals (decel smoke), trough rings (accel smoke) or just an oil that evaporate easier than the previous you used.
Still consider 1 L/5000 km pretty normal
Old 09-02-2009 | 01:32 AM
shayne's Avatar
I have heard this with Motul before. Use a different oil with an appropriate viscosity for the temperature you operate the bike in and see what happens.
Old 09-02-2009 | 10:15 AM
merlyn's Avatar
Thanks! I put only motul 10w40 300 v because is double ester and this is great for an engine life!
Old 09-02-2009 | 10:29 AM
I add oil once or twice between changes, using Pro Honda 10w40, depending on how hard I ride it.
I've had 3 Hondas and 1 BMW and they all used some oil between changes. I top it off if its 1/2 way or less in the sight glass, since oil not only lubricates but cools as well.
Old 09-02-2009 | 10:32 AM
Dan Cronin's Avatar
I'd agree with Shayne's comments. Assuming you careful holding the bike straight on level ground when checking the oil level, I guess the only question I'd add is what volume of oil is needed to make up the difference between the Low / High sight guage marks?
FL02SupaHawk996's Avatar
Fastest Color
+1, don't worry about it...just keep checkin it and you'll be fine...
Old 09-02-2009 | 10:46 AM
If its at the lower mark, it takes almost 1 quart. That's why I keep it topped off.
Its a big bore high performance engine, so some oil use is normal. Riding behind my friend's '02 998 Ducati I can smell the oil in his exhaust sometimes, and he only has about 15,000 miles on it.
Old 09-02-2009 | 07:05 PM
Forde's Avatar
Forde is on a distinguished road
every engine uses oil to some degree
my cars have all used about a litre or a little more, every 5000 miles
i change the oil in the bike every 3k and always keep an eye on the level so unsure how much it uses over a long period
as for where it is in the sight glass is it meant to be halfway up or nearer the top
Old 09-02-2009 | 07:33 PM
Anywhere between the upper and lower marks is okay, just like the Full and Add marks on your car's dipstick. However you don't want it above the upper mark. That could cause foaming of the oil and engine damage.
In some car owners manuals it actually says do not add oil if between marks. I think that's because some car owners would see the level below the full mark and add a full quart of oil, overfilling it.
When I taught Vocational Automotives, we once had a 60s Mustang come into the shop overfilled by 9 quarts.
Old 09-02-2009 | 07:39 PM
RK1's Avatar
RK1
A quart or liter of oil every 5000k or 3000 miles is normal. If you wish to use a bit less, don't fill it to the top line, certainly not over the top line. Fill it between the two lines.
When I've filled to the top line, a few ounces get blown through the breather up to the air box. Fill it half way or 3/4 way to the top line and you'll probably use a bit less of that expensive oil.
Old 09-02-2009 | 07:47 PM
JamieDaugherty's Avatar
IMHO - Motorcycle oil should be changed every 1000-1500.... not 3000 miles. That's way too long. At 1500 miles the oil in my VTR is worn out. I know this because I can tell the difference after an oil change. It's like a haircut, if you do it often enough you won't be able to tell. If you can you've waited too long.
That reminds me, my hair is getting kind of long......
Old 09-02-2009 | 08:05 PM
Since I retired I'm riding almost 1,000 miles a month, so that's a little expensive for me.
Oh, and I haven't had a haircut since 2 weeks before I retired last January.
Old 09-02-2009 | 08:28 PM
RK1's Avatar
RK1
I'm mostly with Jamie on this one. I doubt the oil stops protecting the engine after 1500 miles. But no matter what oil i use the shift quality starts going south at about 1500 or a bit more. Since i use Super Tech 15w40 which i stockpiled at $1.48/quart, cost is irrelevant.
Old 09-02-2009 | 08:39 PM
I have been so focused on mileage to the tank I had not looked at my odo in a while - turns out a great while. Need to mention that the mileage is a little skewed since I installed 15/41. Recent battery out electrical prob after repairs the speedo boots in ODO. 21,000 miles. We just rolled over the Interceptor at 11,000. That's about 9k per bike per year.
Old 09-03-2009 | 06:46 PM
shayne's Avatar
My bikes don't use oil any more. I have no need to top up between oil changes.
I had a BMW that was using oil, so I tried a few different brands. After using 3 brands with varying levels of oils consumption and smoke, the 4th brand I tried (bike shop suggested it) works very well. I have used it ever since (VTR, VFR800 & Suzuki V Strom), and I do not notice any degrading in shifting as Jamie pointed out, although my BMW certainly liked fresh oil in it's separate gearbox.
Not much good for you guys as it is not exported from Australia, and even if it was it would be hard for you to find. But some experimenting can yield results.
Old 09-03-2009 | 10:16 PM
RCVTR's Avatar
VTR cylinders tend to be out of round a bit, because they are unsupported at the top. The rings are very thin and exert a low force on the cylinder walls. This comination causes oil consumption - worse in some engines than others, but not a sign of wear.
Keep oil in it and ride the **** out of it!
Old 09-03-2009 | 10:49 PM
Just_Nick's Avatar
Who are you?
Not really. Synthetic holds up fine for 3k miles.
Old 09-04-2009 | 08:44 AM
RCVTR's Avatar
The oil change interval is based more upon the accumulation of combustion byproducts in the oil than the breakdown of the oil itself.
Old 09-08-2009 | 12:15 AM
shayne's Avatar
Then perhaps part of my "no oil consumption" is due to my engine specs (bored cylinders with custom piston & rings) as well/instead of what oil I use.
maniac2313
05-14-2012 03:21 PM
5150
07-17-2011 08:53 AM
AngryOlaf
05-25-2010 10:39 AM
spladle160
03-15-2010 09:42 AM
CNI Dawg
01-24-2008 09:59 PM
