"Vapor Lock"
"Vapor Lock"
Has anyone else had issues with the VTR stumbling and dying in the rain? I know it’s not electrical because I have carried a spare key and popped open the gas cap (while still rolling!) and it clears itself and runs fine until it happens again. Long ago I remove the plastic “T” fitting that I believe connected the fuel tank breather hose to another hose, with the single hose from the “T” running down (which was purposely “kinked” in such a way to create “P-trap” in the hose) to behind the chin fairing along with the coolant recovery tank and fuel tank overflow hoses. I tried running the fuel tank breather hose directly (without the “P-trap”) to the chin fairing via various routes; and now have it run down to between the alternator cover and clutch slave cylinder to a level below the bottom of the engine (and even cut the end of the hose at a bias with the hole to the rear) in an attempt to create negative pressure on the hose as it runs in the airstream. But even in a moderate rain, the dam fuel tank "vapor locks" until I open the gas cap!!!???
Helpful input with this problem will be much appreciated!
It is usually caused by a low spot in the vent line which allows water to get trapped in the line.
On mine I just made sure the line was straight with no place for water to get trapped and the issue went away.
Mike, I have the fuel tank vent hose as straight, direct and short as possible but it still gives me fits in the rain??
Check that the front plug isn't getting drowned in the rain - as there is a small hole that should allow water to drain from the deep recess and if that gets blocked it can cause problems - as I found out on one very wet ride it causes symptoms very similar to PVLIR.
I've also applied silicone grease around the rubber seal on the spark plug cap to keep it water tight.
I've thought about trying that but with a short hose kept out of the wind. Can the vent line leak gas, as there is no check valve?
Did that 1st thing with compressed air with the gas cap open; it is clear and flows well.
If you review my post, I tried that too.
My problem seemed to clear up after a while while I stopped only to keep reoccuring a few miles down the road in heavy rain. So IMHO something to consider along with all the other vaild answers offered. But if you don't think its worth inspecting in a minute or two to rule out then the OP can choose to ignore my suggestion offered in good faith and from experience.
skokievtr asked "Has anyone else had issues with the VTR stumbling and dying in the rain?"
So while the problem could be from the cause you have listed I would not think it is the likely problem.
It does sound like a strange problem.
Skokie, I have only ever had that problem when I filled the tank too high, and not in rain, but it could be related. If you cap is not venting when wet then that could kinda be the same issue.
I had that issue on a race bike & checking all the gas cap venting (disassemble and clean/blow out) solved it.
It seems obvious its liquid related. If you are sure the vent hose is perfectly clear try looking upstream. Like the drain hole that allows overfilled gas to drain out to the ground.
Just some lateral thinking two cents.
Greg, see above and what would adding a T do (there is none now), and where should it go?
I am pretty sure the tank vents...BUT, is that drain hole on the filler neck rim clear? That is venting. If you over flow the gas tank the surplus should go down that hose(and onto the ground). If it is clogged then it willl cause vapor lock. Blockage could also cause water to build up there & seal off venting.
If you read my prior posts more carefully, I've checked the vent hose & tube for blockages. Next up is a shorter hose, possibly connected to a check valve. I may also try installing my spare gas cap assembly (which is on my modified OE fuel tank I enlarged to 5.2 gallons).
The problem is simulating riding in the rain (at speed) to verify if the "fixes" worked! Any suggestions for that guys?
However, the check valve (see prior post) I have must be pointed up up, so I could attach a short piece of hose to the vent nipple (which points down) under the tank, then connect a T to it. From the bottom of the T a long hose would extend down to the chin fairing as OEM or somewhere more directly downward below the engine), and from the T's side-spigot a short piece of hose would connect to the check valve; with the check valve secured to the petcock so it was vertical. This way on the odd chance the vent did drip gasoline, it would drain to the ground and the check valve would prevent gas from spilling up under the tank.
