Valves hitting piston
Old 07-21-2010 | 07:27 PM
dbog44's Avatar
dbog44 is on a distinguished road
I need some advice, new to the forum and have owned my Hawk with pride for just over a year, I love this machine, but have had a CCT failure. My question is, should i be overly concerned about valves hitting piston? There were no deep marks, just a very light outline of 2 valves hitting the piston. I have a slight divot in top of piston. Should I tear it down???? Don't have the cash to do so, my mechanic says the SH is built like a tank and I should be ok.
Old 07-21-2010 | 07:28 PM
RWhisen's Avatar
Former Superchicken Owner
I would definately pull it down to inspect the valves.
Old 07-21-2010 | 07:35 PM
Bytes's Avatar
Bytes
Bytes is on a distinguished road
Have you done a leak down or compression test? How does it run?
dbog44's Avatar
Sorry I meant to say that I am going to replace all 4 valves, I am worried about the stress on the piston
Old 07-21-2010 | 07:36 PM
dbog44's Avatar
No compression test yet, pulled heads off. Need to replace all 4 valves and both CCT, the I will do a compression test.
Old 07-21-2010 | 08:10 PM
Unless you have a good sized gouge in the head of the piston, you're probably okay just replacing the valves. The valve stems will bend much easier than a connecting rod. You might want to carefully smooth out the "outline" of the valves on the piston head a little though. A sharp edge on the piston could cause a hot spot, leading to pre ignition.
Hope you get it back on the road soon.
Old 07-21-2010 | 08:12 PM
dbog44's Avatar
This may be a stupid question, but what would quantify a gouge????????
Old 07-21-2010 | 08:51 PM
That's a very subjective question. Can you post pics?
Most of my experience is with cars, and the usual repair is to do the cylinder head, smooth out any marks on the piston head, then put it back together.
I did suck a valve in my '69 VW while doing 65 mph on the freeway back in '73 though. The valve head went right through #3 piston. Destroyed the entire engine.
Old 07-22-2010 | 05:03 AM
bjorn toulouse's Avatar
Destructive Tester
If you just bent the valves, don't sweat the piston.
If you broke a valve, definitely tear down time.
Out of curiosity, what RPMs were you turning when it popped?
Rex
Old 07-25-2010 | 06:58 PM
dbog44's Avatar
Thanks for all of the help guys.
I was turning about 5500 rpm's when the cct broke loose, but I was on my way to full acceleration.
FbodyLT1
03-23-2015 07:59 PM
twist
09-24-2012 01:44 PM
uchi
09-20-2010 09:54 PM
SD996
07-18-2007 10:16 AM
chewpick
08-28-2006 08:20 AM
