Valve adjustments.
Old 04-09-2009 | 12:30 PM
Vega (streetfighter)'s Avatar
Vega (streetfighter) is on a distinguished road
Valve adjustments.
I dont know if the previous owner did one, kinda doubt it. The bike is running like a beast and I dont really want to fix whats not broken. Should I get one done even if the bike is running great? Almost 20k miles on the bike.
If I do need to do one about how much would it cost? There are no plastics on the bike so everything should be easy to get to.
Old 04-09-2009 | 01:49 PM
Truckinduc's Avatar
Its really easy if you wanna check the valves yourself. If they are in spec, bolt your valve cover back up and keep riding.
Old 04-09-2009 | 02:55 PM
+1 Shim type adjustment maintains correct valve lash for a long time.
Old 04-09-2009 | 03:18 PM
Little_Horse's Avatar
2nd mouse gets the cheese
yeap its inspection thats on the list every 16,000 so many times no adjustment is needed.
Old 04-09-2009 | 06:08 PM
Can I find out how to do this in the manual? If not I dont need a detailed how to, but a brief rundown on what to do would be helpful.
Thanks fellas,
Rudy
Old 04-09-2009 | 07:29 PM
Page 3-7 through 3-10 of the service manual.
that can be downloaded here:
http://www.superhawk996.net/Honda_VT...ice_Manual.pdf
or here:
http://dl.getdropbox.com/u/219618/VT...3_VTR1000F.pdf
Old 04-09-2009 | 09:50 PM
Thanx. I will check it out.
Old 04-09-2009 | 10:08 PM
Search other threads on valve adjustment. I outlined the step by step procedure on another thread a month or so ago, or check the manual. If you are good with a feeler gauge, you can do it. Checking is pretty simple, actual adjustment requires removal of the cams to swap shims.
Old 04-10-2009 | 04:24 AM
FTMS's Avatar
Just checking the valves is not that big of a deal if you are somewhat mechanical. If you need to adjust them, that takes a little more. It is still not that bad compared to an I-4. Read through the how to threads, then if you have any questions just shoot some out.
superman_006
07-24-2010 11:17 PM
storm_rider
10-04-2009 12:07 PM
01-01-2009 12:44 PM
EngineNoO9
10-12-2006 07:50 PM
ClevelandSuperhawkRumble
03-12-2005 11:23 PM
