Twin Max
Old 06-06-2007 | 09:57 AM
spdrcr's Avatar
spdrcr is on a distinguished road
Twin Max
I am looking into a carb syncronizer. Can you use the Twin Max sync a 4 cyl bike? I don't want to buy something I can only use on twins.
Matt
Old 06-06-2007 | 02:44 PM
bowhawk's Avatar
Make your own using oil. It's more stable, cheap and if you suck oil into the cylinder it won't wreck your bike. I'm sure there are pictures of one here. I use my friends and it works great.
Old 06-06-2007 | 04:09 PM
superbling's Avatar
Yeah, buy for the future and get a multi setup. You can tune a 4 with a twin setup but it's a major PITA.
Old 06-06-2007 | 04:53 PM
torquepeak's Avatar
torquepeak is on a distinguished road
Is there a way to check if the slide diaphragm is sealed after you take it apart and !$%&! with the spring trying to get it in place?
Old 06-06-2007 | 07:17 PM
I think what he's saying here is one tube per cylinder and expect to pay a hundred or so. You never know when there is a VFR in your future. Hehehehe until I'm there. God help me if I ever have to tear this bike down but if I do I won't be taking it to the wanna's at Honda. Four tubes - four cylinders and when they all work together it is soooo sweet.
Old 06-06-2007 | 07:20 PM
trinity012's Avatar
Matt
Hi Matt , I have twinmax sync which i bought from a small dealer from GA this device work just fine for our SH even though it design for BMW. total of cost and shipping around 100< usd. And you need to order this part 16214-MBO-000 $3.45 from your Honda dealer in order to make your carb sync done. You want to know more about carb sync go to Greg,s Honda site will work you thru step by step. James and thanks Gregs.
Old 06-07-2007 | 10:27 AM
spdrcr's Avatar
Anyone know where I can find pictures or directions for this. Has anyone used the Motion Pro Delux or Econo mercury sticks? Is the Econo ok or should I the extra dough for the delux? I found the Econo for 48.40 and the Delux for 80.46 at cycledepot.net.
Matt
Old 06-08-2007 | 09:37 AM
spdrcr's Avatar
What about the vacuum guage type carb balancers? Are they accurate or do the needles bounce too much?
http://cgi.ebay.com/ebaymotors/2-Cyn...21459167QQrdZ1
http://cgi.ebay.com/ebaymotors/Vacuu...21046625QQrdZ1
Old 06-16-2007 | 10:02 PM
Yeah, the guages bounce a lot. The mercury sticks are no longer available IIRC. Something to do with mercury being hazardous or something. I think they're lieing.
Anyway, if you can still get it then go for the better one. I've had both, the cheap one for about 2 years and it broke. I've had the good one for about 5 or 6 now and it's doing just fine. Since it's not used that often, place the brass fittings in a plastic baggie and tape it to the side of the sticks. This will prevent them from corroding.
The Twinmax can be used for a 4-cyl but you have to switch the line for every cylinder and leave the reference line hooked up. It's not that difficult - maybe 10 minutes extra time.
MOONSTER
07-23-2009 06:46 PM
streetfighter996
11-25-2007 11:01 PM
ff
02-02-2007 02:10 PM
sparky
08-18-2006 06:17 AM
inderocker
12-26-2005 02:00 PM
