Turn Signal Flasher Relay Wiring
I did search. I found some good info, but not what I was looking for.
I put on Motrax Arrow LED turn signals.
I also bought a Motrax Universal Flasher Relay.
My problem is, the relay comes with only Black and Red wires. While the stock relay has 3 wires; White/green stripe, Gray, Green.
From the reading, one of them is power in parallel for the brake lights, correct?
So is it safe to assume that I can put green to black, and combine White/Green and Gray to red?
If not, who has info on a LED flasher relay that is a direct plug in for Honda.
Thanks.
Erik
Thanks.
Erik
Green is the ground. White/green from the harness is hot, grey outputs to the signal switch. Not really sure why the new flasher doesn't need a ground, but that's the way mine is wired and it worked.
Les
02-12-2006 01:23 PM
