trans messed up after je piston install
I got my motor back and even before starting it i noticed i couldnt find neutral than, what i found it where 5 th gear should be and the whole line up of gears is wrong someone please need insite badly
Maybe the end linkage is just upside down. Look at the first pic in this thread. If it looks like this (end arm that attaches to the shift gear on the bike is pointed up), then you have reverse shifting. All you need to do is loosen that 10mm bolt and flip the little aluminum arm over.
https://www.superhawkforum.com/forum...hifting-27577/
Edit:
Reverse shifting:
Stock linkage placement (different linkage, but you can see the positioning)
Edit:
Reverse shifting:
