trail Tech vapor install
Old 08-25-2011 | 11:18 AM
RumbleBee's Avatar
RumbleBee is on a distinguished road
ok, I’m working on installing a trail tech vapor on my 99vtr1000. Everything is working great except the darn tach sensor. The issue is that i have the vapor set 0.5 for the PPR...it’s the only way to get it to the read the rpm close to right. it’s still jumps around but it’s frustrating me. I tried changing the setting to 1 on the ppr and it will read nothing. I'm also not sure if this bike changes ppr values at a different rpm level. Mind you this is my first bike so i am unfamiliar with this.
Can anyone provide insight or help me out on this?
Old 08-25-2011 | 02:17 PM
geekonamotorcycle's Avatar
I am going to be getting one of these soon and would love to know what your install process was. did you get any pictures or video? did you remove your gauges and mount it? did you keep your gauges(this is what I want to do)?
Old 08-26-2011 | 11:57 AM
TTHelper's Avatar
TTHelper is on a distinguished road
Tach install help
How do you have the tach sensor lead installed and grounded? Are you using the tach sensor wire with the built in resistor?
Old 08-26-2011 | 08:48 PM
slabm7's Avatar
I have one of these on my XR650R and I would like a bit more info as well, the pre 01 guages suck. How hard was it to install? Any pics of it mounted? Any more info you could give us would be great, Thanks.
Old 08-26-2011 | 09:19 PM
K30's Avatar
K30
K30 is on a distinguished road
If you're using the stock tach lead, I'd say try and pull the signal directly off a coil. On my XR400R that is what I did and it works great. It was pretty simple to install, the thermocouple was the PITA.
Old 08-30-2011 | 06:16 AM
nothing's Avatar
ride it out
I tapped right off of the wire going to one of the coils and put a 600k ohm resistor in series between the coil and vapor. works good
Old 03-20-2012 | 07:58 AM
COLE's Avatar
Crash
trail tech doesn't offer one specifically for hawk so which one are yall using? does it matter? I bout to order one for my hawk.
Old 03-28-2012 | 10:41 AM
Carolinaboy's Avatar
Carolinaboy is on a distinguished road
I would also like to know which vapor you guys are using.
Old 03-28-2012 | 12:58 PM
kai ju's Avatar
I've had one on my XR650R for about 3 or 4 years now.
I wrapped the Tach sensor lead around the plug wire and have never had a problem. Did about 7 or so windings.
Don't use the trigger wire, it's really happy with the plug wire.
If you slip heat shrink tubing over the wire it makes for a very clean installation.
Old 04-01-2012 | 07:38 PM
new2thehawk's Avatar
been there crashed that
new2thehawk is on a distinguished road
I am building a streetfighter and want to use the vapor stealth. Did you get the problem solved? What were your settings for speed?
To cool that you guys are trying this, I have cluncky 98 gauges... Just swapped out a beat 98 motor for a sweet low milage 2002 and making risers now for mx bars. Going to mount vapor to them and get rid of huge subframe.
Old 06-05-2012 | 08:51 PM
COLE's Avatar
Crash
I bought the trail tech vapor. I d sure like to see pic of how you mounted speedometer to caliper and rotor, not really liking how mine's looking...
kai ju
12-11-2014 01:33 PM
scpt kirk
03-06-2013 09:38 PM
skokievtr
01-08-2013 06:08 PM
WOMPY5000
07-16-2012 06:15 PM
khanawalt
04-03-2007 10:02 PM
