TPS - No reading ???
Old 05-21-2008 | 12:00 AM
Reb's Avatar
Reb
Reb is on a distinguished road
How would a hawk run if the TPS was not working. I have tried to measure my settings but get NO readings at all. No volts or ohms. The meter is working ok. The bike runs sweet. Whats going on.
Old 05-21-2008 | 05:53 PM
It wouldn't run much differently at all. Did you measure resistance at the correct terminals per the Service Manual?
Old 05-21-2008 | 06:58 PM
Reb's Avatar
Reb
I followed the service manual and even checked both ends of the TPS plug - nothing. Did the unplug replug at 3500 revs. No difference. I tried to check the readings at the ICM. The manual seems to show it located under the seat near the back of the gas tank. My bike (2001) has nothing like it. Just a bunch of electrical connections in a clear plastic cover ?? Where else would it be. Thanx.
Old 05-21-2008 | 07:01 PM
You have to read off the 2 little spade contacts recessed in the TPS itself. It is difficult to maintain good connections while turning the TPS (i.e., grind slots in the tamperproof screw heads with a dremel tool). I replaced the oem screws with appropriate hex head cap screws and fabricated a plug that fit the TPS. Alternatively, you can crimp on a t-tap to the insulated wires that connect to the TPS and read with your ohm meter (with ignition obviously off) thru the t-taps. Then seal the t-taps with dielectric grease.
Old 05-21-2008 | 07:38 PM
RK1's Avatar
RK1
On my '03 the ICM is under the seat but over on the left side between the seat rail and the tail plastic, just about right above the rear axle.
brookslee1
01-07-2013 05:52 PM
Dan Cronin
01-02-2011 08:54 AM
uchi
08-25-2010 01:20 PM
cliby
Motorcycle News
05-06-2008 07:52 PM
tdaddylove
09-21-2007 10:49 AM
