TPS mod
Old 01-31-2005 | 07:26 AM
superbling's Avatar
Re: TPS mod
Welcome,
Yes there's a good link. I followed it when I did mine. Just look in the knowledge base section of the forums. It's the one labeled: throttle position sensor.
The only thing I'd like to add is this: mine was too far out of adjustment for the correction slots to handle. I simply pushed out the metal ringlets for the screw holes. This allowed me to rotate the tps sensor a little bit more to get it back into acceptable range. Also, I used a dremel to slot the "headless" screws and a screwdrive to remove them. I'd also suggest punching the screws with the screwdriver and hammer first to break the locking agent.
brookslee1
01-07-2013 05:52 PM
call me phil
05-17-2005 06:49 AM
mikstr
04-10-2005 10:37 PM
cozart02
04-02-2005 02:54 PM
troy_v
03-25-2005 09:48 PM
