Torque Spec for tightening Chain
Old 05-07-2007 | 12:29 PM
F1 Fan in Nascar Land's Avatar
F1 Fan in Nascar Land is an unknown quantity at this point
My friend is going to do this for me and I was wondering do you need to loosen the rear axel bolt (as you can tell I may know how to ride but not how to maintain the bike) and if so what is the torque spec for that.
Thanks guys
Old 05-07-2007 | 12:42 PM
seaton001's Avatar
seaton001 is on a distinguished road
93 NM or 69 FT/LBs
Old 05-07-2007 | 01:59 PM
Thanks guys
Its a 2003 Superhawk if that matters
Old 05-07-2007 | 04:12 PM
seaton001's Avatar
All the same...
Old 05-08-2007 | 08:47 AM
swordfish's Avatar
just loosen the axle bolt. fiddle the adjusters making sure that the markers on either side are equal. once you like your amount of chain tension, then make sure your sprocket and chain are lined up.(I eyeball it, but there are more exact ways) lock that axle bolt down tight(never used torque specs) then lock down the adjust locking nuts. make sure you measure the chain tension at the longest run of the chain. better too loose than too tight.
Old 05-08-2007 | 10:50 AM
L8RGYZ's Avatar
I usually go for 1.25 inch deflection when adjusting the chain. Puts it at the low end of the spec.
YTKinWI
02-27-2012 07:11 PM
smokinjoe73
08-21-2011 07:13 PM
Mr Toad
01-19-2010 04:26 PM
01-26-2007 01:25 PM
AbeFM
09-12-2005 07:41 PM
