timing
Old 04-06-2011 | 02:06 PM
vtr1000f/99's Avatar
vtr1000f/99 is on a distinguished road
timing
hello again guys need help on how to adjust timing
Old 04-06-2011 | 02:18 PM
Rear cylinder, right? Search around the site and find the .pdf. It tells you how to adjust timing in the same section that you do valve clearances...
Old 04-06-2011 | 02:20 PM
thetophatflash's Avatar
As far as I know, timing is only adjustable by replacing the advancer. I've got the FP 4 degree advance.
Old 04-06-2011 | 02:47 PM
I took the camchain tensioner off the front cylinder and the chain let loosnow the front intake valves are closed and the rear are open
Old 04-06-2011 | 02:48 PM
Do you have the valve covers off?
Old 04-06-2011 | 02:49 PM
Check out the end of this thread:
https://www.superhawkforum.com/forum...pe-ccts-11275/
The last pageis a recent discussion related to setting the timing. If you're at TDC, you won't have half of these issues, but it's a start.
Old 04-06-2011 | 03:16 PM
no i dont have the valae covers off
Old 04-06-2011 | 05:25 PM
Knowledge base> service manual https://www.superhawkforum.com/forum...-manual-11365/
Down load the link, and follow the procedure for setting the timing go to para 8-21.. page 166
Old 04-06-2011 | 10:05 PM
nykuryu's Avatar
nykuryu is on a distinguished road
that is confusing me. i have the FE and FI lined up with the flanges on the outside of the cams at the FT timing mark. every 2 rotations they are lined up again, correct timing? what next?
Old 04-07-2011 | 10:45 AM
nykuryu's Avatar
bump
Old 04-07-2011 | 11:34 AM
Line up the front cylinder. Rotate the crank 3\4 of a turn (or 270 degrees) counterclockwise and line up the RT mark. Then set the rear cams.
Old 05-11-2012 | 08:44 AM
DrewMan996's Avatar
Young Hawk!
DrewMan996 is on a distinguished road
Hey 8541Hawk, so line up the rear cams just as the front cams? with the FI and FE parallel to the head at opposite ends? (basically all valves closed)
Old 05-11-2012 | 10:00 AM
On the rear cylinder you would use the RI & RE marks on the cam sprockets
The cam lobes will be pointing the opposite direction than the front but other than that it is the same as the front. Line the marks up so they are parallel to the head and you are good.
Old 05-11-2012 | 10:49 AM
aja's Avatar
aja
Don't forget to line up the RT also. Watch the cam lobes to ensure you are properly aligned with RT before you reset the timing, I forget when it is aligned but I beleive when you are directly between the two letters, if I am wrong someone correct me.
superchicken
12-13-2007 12:50 PM
superchicken
10-08-2007 10:56 AM
cliby
03-01-2007 10:55 AM
ATLSHawk98
01-05-2007 09:22 PM
dustinwild
06-16-2006 08:36 PM
