Is there an easy way?
Old 03-16-2010 | 06:49 PM
98ILVTR's Avatar
To adjust the fuel screw/pilot screw without taking the whole carb off again? I have taken the carb off a lot in the past 2 weeks, probably so much that I could do it in my sleep, but it would be nice to not take off the airbox, etc...
Old 03-16-2010 | 07:39 PM
uchi's Avatar
depends how big your hand is. when we did my carbs john was able to shove his hand under them and adjust them with the little tool. its tight but he made it work.
Old 03-16-2010 | 07:41 PM
Killemall's Avatar
I don't think so. The only carbs adjustment you could do on-the-fly is the A/F mixture but you got to shell the money for a Flo-commander.
Old 03-16-2010 | 08:17 PM
slo1's Avatar
slo1 is on a distinguished road
That's my method as well
Old 03-16-2010 | 08:19 PM
98ILVTR's Avatar
Man, thats a tight squeeze, even with the PAIR Valve gone. I'll have to see if I can do it...
I also found this, its cheaper than a Flo-Commander...
http://www.motionpro.com/motorcycle/partno/08-0119/
Old 03-16-2010 | 08:21 PM
trinc's Avatar
you can buy a right angle screw driver for $25 then remove the honda D screw and dremel a slot in it. or buy the motion pro tool for $80 and bitch that their D bit sucks and remove the D screw and dremel a slot in it... then use the motion pro flat blade bit.
tim
viperkillertt
07-30-2010 09:27 PM
CentralCoaster
03-18-2009 05:45 AM
rbrais
10-07-2008 12:43 PM
SuperHawkins
10-16-2007 05:15 PM
zimm
09-27-2006 01:02 AM
