Taking off stator cover...
Old 04-13-2009 | 01:59 PM
L8RGYZ's Avatar
... left side engine cover.
I want to take this side cover off to clean out some metal shavings & replace a gasket, but I don't want to change the oil.
Am I correct that this side really has no significant oil flow?
Old 04-13-2009 | 02:19 PM
j shizzy wizzy's Avatar
mildly retarded
I'm interested in replacing mine cause its all scratched up, so I am curious what is going on in there too!
Old 04-13-2009 | 02:41 PM
Truckinduc's Avatar
Tip over the bike and prop it up on the right side. Get a significant angle and you should be fine.
there is just a stator and flywheel in there
Old 04-13-2009 | 04:03 PM
BeerHunter's Avatar
Slacker
No Significant Oil Flow
You are correct in that the left side cover (stator) does not significantly contribute to the overall oil usage of the engine unit. I see no reason to perform an oil change for such a simple task as removing that cover. You should expect a small amount of oil to drain out, a few ounces at the most. Once the repair is complete be sure to check the oil level after running the engine, just to be safe.
Old 04-13-2009 | 05:38 PM
loserbaby's Avatar
jet wrench
loserbaby is on a distinguished road
If your removing metal shavings... I would strongly suggest an oil change. What makes you think there's metal in your crankcase?
Old 04-13-2009 | 07:12 PM
L8RGYZ's Avatar
Thanks guys (and gals?). Spot on.
Well, previous mechanic tightened the aluminum Crankbolt Hole Cover (the big one in the middle of the left side cover) to about 100lb/ft. So I stripped the hex bolt hole trying to get it off. My friend tried several ways to get it off unsuccessfully & finally just drilled thru the cap in several places to make a slot in the cap, shoved the handle of an adjustable wrench into the slot & turned it with some vicegrips or something.
So the hole was full of metal chips & shavings. Anyway, yes, very little oil gets into this area; not even enough that a drop would come out. There is really no way for anything in the stator area to get into the crank case, but those shaving just bugged me.
Old 04-14-2009 | 10:32 PM
Circuit_Burner's Avatar
guru of things sparky
That part of the engine is not sealed guys.
And oil level is gonna be oil level , all the way across the case. Its physics.
The mag stator is cooled by the engine oil also, so they make sure a sizable amount of oil exchange takes place there.
So when you crack that side cover oil will run out with a quickness.
Do like someone said earlier, and what we would do with our MX bikes,
lay the bike over 60 degrees or more and work on it without draining oil.
( tip, be careful not to damage your stator, its easier than you think )
Old 04-14-2009 | 10:59 PM
comedo's Avatar
I checked some old posts and I think L8RGYZ has been through the seized crankshaft hole cover thing before. Me too. They will seize even if they've not been overtightened. I loosen and retighten the crankshaft hole cover and the timing hole cover a couple of times a year to ensure that they don't seize.
Crashrat
10-11-2012 09:25 PM
joshuatest
08-20-2009 04:08 PM
L8RGYZ
03-10-2008 01:36 PM
Tempest
09-20-2006 08:35 PM
cat0020
06-12-2006 09:18 PM
