tachometer wiring
Then you can either read the manual that came with it, or/and tell us which one it is, and it's possible we migth be able to help... But with the current amount of info my best advice is.... Eh.... Good luck!....
Um... green wire to coil as in the signal for the coil then... Not really the tacho signal then... So if you have it wired at the plug up front, it probably won't work...
Not sure where you did wire it though, so I'm guessing...
i pulled the guage cluster and wired the new tach off the leads that went to the old one as they were labeled off the back of the cluster assming the yell/grn wire which was the only unlabeld one was the said signal from the coil.... was that assumption wrong? if so where would i find the appropriate wire?
That wire is indeed the tacho signal wire for the stock cluster... But that's not the same as coils unfortunately... The tacho signal is 5V, the coil signal is not 5V... Hence no movement...
The coil signal is down the frame towards the coils, yellow/blue for one and blue/yellow for the other... Have a look here... It should help some...
http://tweety.se/download.php?file=V... Superhawk.jpg
okay that is an illustration of what i already understood... why does that yellow green wire not work? are you suggesting i connect to the wires between the coils and the ignition cont unit? im lost brother.. why would this be sofa king complicated
The wire you are using now goes 0-5-0-5-0-5... The other goes 12-0-12-0-12-0-12... The tacho is nearsighted and doesn't see stuff smaller than 11...
Doeas that help yer thinking parts...
Yes, the two wires between coils and ignition unit... just pick one of them...
alright im connecting to the yellow/blue wire that runs from the coil to the converter unit from #2 why is it still not working? i tried it before and after the connection to the rest of the harness... still nothing? is it possible that this tach doesnt work with our bike? im really starting to get worried.. i am way past the point of no return to go back to stock....
http://www.phatperformanceparts.com/..._p/49-3374.htm
its litterally the cheapest one i could find and i know it only goes to 8 and our redline is 9and change...
sorry i didnt mean to say 9 and cange i meant 10 and change thank you sooo much for you technical guidance i will now go fix my bike and ride off into the sunset... you gaint floppy *****...
Carry on.
yup your tach does work... and right now i wish i had never started this build but i did. and addmitedly calling you a ***** was a bit of a dick move sorry i just woke up with no patientce today and your little gem of knowledge grinded me the wrong way. not in anyway your fault. so my bad. i already read your sig and dont expect any helpfull insight from here on.. i just dont want anyone else to think im actually THAT nice to EVERYONE i dont know...
Good luck with your project.
