Stuttering & Sputtering
Old 08-24-2008 | 01:29 PM
mn.cadena's Avatar
mn.cadena is on a distinguished road
I have an 03 Superhawk with 22k on it. I recently had the oil changed along with replacing the spark plugs, air filter and having all the fluids checked (brake and clutch fluid looking pretty murky). When I got my bike back I was told that the fluids were fine and didn’t need to be changed. When I ride it now it tends to buck when trying to maintain a constant speed, and when I give it some throttle it bogs down before giving any acceleration. Once acceleration begins it bucks again. This was never a problem prior to taking it in this last time. What can be done to fix this problem?
Old 08-24-2008 | 02:29 PM
drew_c14's Avatar
When they changed the air filter did you go from stock to aftermarket or the other way around?
Old 08-24-2008 | 02:32 PM
mn.cadena's Avatar
I went from stock to aftermarket.
Old 08-24-2008 | 02:41 PM
MisfitToy's Avatar
Shredding Asphalt
also heard of it happening if a hose gets pinched. also aftermarket like a K&N more than likley brings the need to rejet
Old 08-24-2008 | 02:47 PM
mn.cadena's Avatar
I have also heard that using "Seafoam" might fix some of this problem?
Old 08-24-2008 | 03:10 PM
drew_c14's Avatar
Seafoam used correctly can't hurt anything.
Try riding with the choke out a little bit, I suspect your problem will get a little better. If it does you know you're way lean and need to re jet. Or if that's something you're not interested in just go back to stock air filter.
Old 08-24-2008 | 05:16 PM
mn.cadena's Avatar
Can switching to an aftermarket air filter amke your bike run worse? I thought the whole point of that was so that it would perform better?
Old 08-24-2008 | 05:56 PM
drew_c14's Avatar
It will make it run better, if you tune the carbs to match. You have thrown off the air/fuel ratio. You now have more air than is right for the amount of fuel.
Old 08-24-2008 | 06:11 PM
mn.cadena's Avatar
What is the average cost or time for labor to have the carb tuned to match?
Old 08-24-2008 | 06:13 PM
drew_c14's Avatar
That's a tricky question. The jet kit itself is around $90. The labor can get pretty steep if done right though, sometimes the carbs have to come off 3 or 4 times. Some people will probably just go with recommended settings and call it good after one try.
Old 08-24-2008 | 06:26 PM
mn.cadena's Avatar
Do I just need to buy the jet kit and take it into the mechanic? Anything else needed?
Shane702
04-19-2013 11:35 AM
zixxer
03-15-2009 06:07 PM
iamanonymous
03-07-2007 04:13 PM
zimm
01-12-2007 04:01 PM
matix
10-06-2005 07:57 PM
