stuttering, bucking, misfiring at steady 2-4k rpm
The superhawk is acting up. At steady speed between 2000-4000rpm, like going 30mph, the engine "hiccups" quite a bit. It sounds like a misfire, engine bucks and then smooths out. I think it's running lean, but I'm not sure. I have devil pipes and a K&N jet kit. The jet kit has been in place for 22,000 miles with no problems before.
I'm thinking about re-syncing the carbs and checking for vacuum leaks. Maybe I should also change the plugs. Any other suggestions? Anyone have this problem?
It runs great while accelerating or running on the highway.
Mine was behaving identically and in roughly the same condition (jet kit, pipes, mileage) as yours. Going up a notch on the needles did the trick.
CentralCoaster
09-13-2008 01:51 AM
iamanonymous
03-07-2007 04:13 PM
