stumble at 7k rpm
stumble at 7k rpm
ok seein how i cant get an answer on the old thread, thought id start a new 1... just did my ccts and my timing was way off, im 99% sure the timing is dead on now but my bike wont go past 7-7500 rpm. any ideas on that? did a bafflectomy a few days b4 the ccts went out but i would still redline no prob
I used to run into that kind of problem with carburetor equipped cars from time to time. Sometimes they would just die if you floored it at a certain speed, then you'd let off the gas and it would run fine as long as you didn't go over that certain speed. 9 out of 10 times it was a clogged fuel filter. It even happened to my '70 Chevy Nova SS while it was still under warranty. The dealer did all kinds of stuff trying to find the problem, then they dropped the tank and found the filter sock was clogged.
Check your fuel filter for contamination. Unless you've added inline filters, the only filter is a "sock" type attached to the fuel outlet/petcock assembly at the bottom of the tank. It might be coated with gunk.
If that's not it, try cleaning the carbs. Could be a restricted jet. Also check the carb diaphragms.
Please update when you have found the problem. I seem to have the same issue Iv just had my motor replaced.....and now this has started. ( However, mine is the Honda VTR Firestorm )
She has all the pull off power in the world, but around 5.5K RPM, it feels like she is running out of fuel, then comes back, and does it again. It limits at different revs per gear.....I suspect its carbs and settings tho.
The other cause for this kind of problem is the side stand switch. Check to see if it is loose or dirty. You can also by pass it to test to see if it is the problem but I would recommend either repairing or replacing it as it is good to have one on your street bike.
Red_Liner740
07-20-2008 01:51 AM
