Stock Header size?
Old 09-28-2007 | 12:51 PM
Cleveland's Avatar
Post Whore Junior
Stock Header size?
Ok, SO I've got this guy that can mandrel bend tubing and pipe but only 1 3/4 inch size... Is that the size of the header pipes? Or are they 2''? Would 1 3/4 tubing be ok size wise? Doesnt seem like it'd be too much of a difference.. Not concerned with the material that the tubing is made of at this point.. just want to establish if the size is OK...
Old 09-28-2007 | 01:59 PM
hawxter996's Avatar
ole dirty bastard
1 3/4 is fine for header.
that is what im using for custom setup im working on.
Old 09-29-2007 | 12:22 PM
redman's Avatar
It matters alot!!!
If your engine is stock, go with stock size tubing. Exhaust back pressure is very important to torque and top revs HP. If you have extensive engine work....cams, hi comp, flowed head...THEN you may want larger than stock headers.
Old 09-29-2007 | 02:04 PM
hawxter996's Avatar
ole dirty bastard
Originally Posted by redman
It matters alot!!!
there are other variables other than tube size.
but since he is doing custom work,he will probably
need to do carb work regardless.
and 1 3/4 is so close to stock size that in itself wont matter as much as collector shape,
length of pipes etc.
Old 10-01-2007 | 06:57 AM
Cleveland's Avatar
Post Whore Junior
hmmm.. thank you for the info...
HawkRider98
09-09-2012 03:48 AM
Woody42181
04-04-2011 11:07 AM
thirty_ought_six
04-28-2008 06:51 AM
calitoz
03-10-2008 06:06 PM
cliby
04-27-2007 08:58 AM
