sticky throttle...
Old 02-23-2007 | 06:40 PM
call me phil's Avatar
call me phil
sticky throttle...
i was hoping someone could help me here. my throttle seems to stick when it is cold outside. not so much a problem during summer, but kinda bothersome during cooler rides. my question is, how do i remove the throttle slide to clean and lube it, i can almost slide it off the clip on but it gets hung up from the cables. and i cant figure out how to remove the clip on. all help is appreciated.
Old 02-23-2007 | 09:02 PM
Thumper's Avatar
Are you sure the throttle tube is not just dry, Try the simple stuff first like shooting some WD40 in the throttle tube area first
Old 02-24-2007 | 05:18 AM
+1
If that fails then you have to remove the throttle cables from the carbs, or alternatively remove the clip-on and slide the tube off. The clip on is held on by a single clamping bolt, IIRC.
chemomche
03-19-2012 03:09 AM
joshuatest
Forum Feedback
12-23-2007 08:23 AM
Arctic Fire
12-14-2006 07:50 AM
jmalys
07-14-2006 05:42 PM
