Stater/generator cover
Old 06-06-2007 | 04:53 PM
printdoctor's Avatar
printdoctor is on a distinguished road
Just wanted to know how to get the stater/ generator cover off the engine and is there any tricks to it?
Thanks
Old 06-06-2007 | 06:01 PM
Using the online parts fiche is a great tool. RonniesMailOrder.com or servicehonda.com are great tools. Service Honda is a bit more computer intensive. Ronnies is great - fast - easy interface - shows you all the parts and gives you a parts list for ordering if you wish. I've done business with them and completely AOK. I have no other affiliation. Just good folks, not the best price.
Old 06-06-2007 | 08:04 PM
superbling's Avatar
Yeah, there's a big trick: it uses bolts! JK
After you remove all the bolts, it will still stick because of the heavy duty magnetism and the gasket can stick. Tap it with a rubber mallet a time or two and pull hard.
Old 06-06-2007 | 11:52 PM
Thanks for the help! I have someone sending me the cover and they weren't quite sure. Thanks again!
Old 06-09-2007 | 01:31 PM
BiggDaddyKool's Avatar
BiggDaddyKool is on a distinguished road
anyone know how to remove the stator from the cover itself without harming the stator ??
Old 11-07-2008 | 01:17 PM
RI-redhawk's Avatar
RI-redhawk is on a distinguished road
I'm trying to remove the cover. do i have to remove the cluch slave to get the cover off???? Its unstuck from the gasket but the clutch slave seems to stop it from coming off.
Old 11-07-2008 | 06:23 PM
dakmatik's Avatar
dakmatik is on a distinguished road
yes, the slave has to come off.
Old 11-07-2008 | 06:37 PM
noof's Avatar
noof is on a distinguished road
There's 4 socket bolts holding it on to the inside of the cover (one of the bolts holds on a plate that makes sure the wire doesn't get chewed up by the flywheel.)
Little_Horse
09-10-2012 08:35 AM
peterdamian2000
08-25-2011 07:20 PM
Montana
07-28-2011 02:11 PM
ozzie9962
04-13-2009 01:16 PM
Reb
09-10-2008 02:37 PM
