So how do I adjust the idle screw with the carbs installed?
I installed the carbs thinking I could tweak the screws with them in but so far no good. Hands too big, brain too small.
I can't do it. And I can't find a tool to do it other than the Honda one for about $300. What you need is the motion pro tool with a D shaped bit, but they only offer it with a slotted bit.
I've heard you can cut a slot in the needle. Or hire a midget.
www.motionpro.com ph 650-594-9600
I've decided to replace my emulsion tubes so I'll adjust them then. Its going to suck if I have to adjust them again.
Anyone know baseline for a stock bike with a stage 1 dynojet kit with 185/180 mains, needle clips 3 up, and a stock 45 pilot? I live at about sea level. The kit says 2.5 turns out but I remember most people running around 1 3/4.
thedeatons
06-21-2015 10:11 PM
DaxMiddler
04-28-2006 04:22 AM
02MONSTERHAWK
04-13-2006 10:34 AM
