Slow turn signals
Slow turn signals
Just brought a 2001. Guy said he jump started it from a car because battery was dead. After it was running he noticed that the left turn signal takes a couple / three seconds to start blinking, which he said used to work fine. Any ideas what's up with it? Only thing I can think of is the turn signal relay or a messed up switch. It takes a couple seconds the first time and then gets quicker second time and quicker third time. Then 10 miles down the road it takes 2/3 seconds again.
Thanks for any input.
This uses the same relay (flasher) for the right and left turn signals. I would check for corrosion in the bulb sockets first then inside the switch. If you have a multi-meter you could check for continuity beween ground and the wire that goes from the switch to the flasher. I dont have a wire diagram... but I am sure that someone can let you know what color wire youd be looking for.
If both the front and rear signals on the left are affected it could be a dirty switch. Take it apart, carefully because of the springs and detent *****, clean it up and lube it lightly. Hope that works.
mines weird sometimes, if the bike isn't warmed up, the blinkers will take up to 30 seconds to start blinking. once I've been riding for a while they come right on. dont think that is a dirty switch problem though, what do you guys think?
'Had to jump from a car battery...'
'Worked better after the bike warmed up...'
Slow turn signals, lack of starter motor enthusiasm, odd backfire all went away after I rebuilt the charging system. The big suggestion is to pull the battery and have it load tested. Sure, the signal contacts could be marginal and there is no harm in checking 'em, but if I could wager my bet is on a weak or marginal battery with perhaps an underlaying R/R issue.
Here's hoping it's just contacts, they're a lot cheaper to fix.
as far as my case the battery is fine, new before winter and been on a tender all winter. R/R just replaced, still slooow reacting turn signals. heck I just went for a ride (it's 80 out right now) and they didnt hesitate at all, button on turn signal on.
I have a similar problem on my '98, although it's only a 1 second delay. It hasn't been long enough to bother me. I do have an aftermarket R/R with matching alternator/stator that might be playing havok with the switch or relay.
I figured it was a problem with a relay, and I tend to avoid making changes to my electrical system as its problematic enough.
Thanks for the input from all. Seems that it's working fine now. I think the former owner had it sitting outside all winter under cover and probably some bug climbed up in the switch housing. Maybe that since I'm riding it more than he did, whatever was the problem it came out, be it dirt/bug/?.
my signals do the same thing and it's pretty much random, sometimes they won't come on for a few minutes, at that point I'm no where near a turn. I think mine is due to dirty contacts since someone used wd40 (I think) when I... uh I mean he was cleaning them a year or so ago.
My bike is slowly developing the symptoms you have listed- slow turn signals when cold or damp, and occasional backfire when starting.
CentralCoaster
03-06-2015 08:46 PM
Magnus
05-29-2014 07:52 PM
johnclopp85
05-13-2009 08:20 AM
skokievtr
05-01-2007 11:11 PM
