Seafoam????
Old 02-09-2009 | 03:11 PM
Vega (streetfighter)'s Avatar
Vega (streetfighter) is on a distinguished road
Seafoam????
Has anyone ran Seafoam through the gastank on here? I heard this stuff is pretty good at cleaning out gunk and will help the bike run smoother. If so how much of the can did you use?
Any feed back on if its ok to use or not.
Thanks..
Old 02-09-2009 | 03:13 PM
Randman uses a couple capfuls at each fill. Something he learned from his Dad. I'm answering for him bc his new computer will not arrive until tomorrow and I know he is an avid proponent of it's use. I use it too.
Old 02-09-2009 | 03:15 PM
Truckinduc's Avatar
Ive used it in cars. Some in the gas, some in the oil right before you change it.
If you use alot it will smoke like hell, like its supposed it.
Old 02-09-2009 | 03:26 PM
pigwings's Avatar
pigwings
Yes. Good as StayBil
Old 02-09-2009 | 04:19 PM
I've used it on my cars. Never tore down the engines so I can't confirm it's working as advertised. I always used a vacuum line to suck it into the intake eventually enough to stall the motor. Let it sit for 5 min, start it up and watch it smoke like crazy. It's never caused any problems.
Old 02-09-2009 | 04:44 PM
HondaJim's Avatar
Will drum for BBQ
HondaJim is on a distinguished road
I've put a whole can in the tank of a carb bike at fill up. Just be careful, the stuff is 100% petro, and it will eat paint according to the directions.
Old 02-09-2009 | 06:28 PM
I run a bit through mine from time to time and it works fine
Old 02-09-2009 | 07:30 PM
MLB's Avatar
MLB
MLB is on a distinguished road
Been plenty of research on this, google it. Been around for 50 years or so. Shouldn't hurt anything unless you overload it and hydrolock. Won't really do any good either.
Old 02-09-2009 | 09:51 PM
j shizzy wizzy's Avatar
mildly retarded
http://www.jeepsunlimited.com/forums...hlight=seafoam
some good info. form a ton of people.
Old 02-10-2009 | 03:22 PM
steve.g's Avatar
Seafoam is good stuff.I use it in my bike and pickup as a fuel system cleaner.Half a can in the bike,full can in the pickup,gas up and go...
Old 02-10-2009 | 03:40 PM
cameron's Avatar
ive always used half a can in my bikes when i feel the carbs might be getting a little dirty. used in my katana and it really smoothed it out good stuff.
Old 02-10-2009 | 09:25 PM
bigpat123's Avatar
bigpat123
i do it before i put the bike up and also a couple of times during the season. I did it for all my cars and never had a problem other then spilling it on paint learned the hard way on a 88 civic hb
Old 02-10-2009 | 09:48 PM
Randman's Avatar
Moderate-whore
Most excellent....
I use that Chem tool stuff as well...
Old 02-11-2009 | 06:11 PM
MLB's Avatar
MLB
Around here it's also known by the more generic term: Snake Oil.
Old 02-15-2009 | 06:30 AM
As long as you use good gas and winterize properly then you won't have to use this stuff. The big carbs on the VTR also have big jets. They do not clog easily. At one point in my bike's life she sat for almost a year and started right up afterwards. That was without Stabil too!
TboneNast
06-10-2014 05:39 PM
996thehawk
07-14-2013 01:10 PM
