Replacing my R/R
Old 02-24-2009 | 07:32 PM
jkrswld's Avatar
jkrswld is on a distinguished road
Replacing my R/R
New R/R came in now I need to replace it can anyone help me out with this. I was told it is fairly easy just need to know where to start.
Old 02-24-2009 | 07:44 PM
skoshere's Avatar
here you go...
https://www.superhawkforum.com/forum...ad.php?t=14380
Old 02-24-2009 | 08:54 PM
For a simple swap with OEM parts, remove the seat, remove the rear cowl. R/R is on the right side, has two bolts, and one connector. Check connector cleanliness and overall physical integrity and also check the mounting area on the subframe for cleanliness. Half of the heat removal is probably through that contact on the subframe.
Old 02-25-2009 | 02:29 PM
jkrswld's Avatar
Thanks should be swapping it out tonight and riding tommorrow!!!!!!!!!!
Old 02-26-2009 | 03:03 PM
PUSHrod's Avatar
and take an extra five minutes to clean out any corrosion you find on the ground or the connectors. Di-electric grease completes the job and forestalls the time of the next failure.
mikstr
05-03-2007 06:38 PM
Otto Man
01-06-2007 02:36 PM
seattlesucks
06-23-2006 02:49 PM
mikstr
06-16-2006 08:36 AM
smonska
05-31-2006 05:45 PM
