Replacing Clutch Lever
The clutch lever has a cylindrical brass insert in it with an indentation. There's a small post in the plunger the lever pushes against that has to fit into the indentation. Other than that, it's pretty much the same as changing the brake lever. It'll probably take more time to find a flat screwdriver, grease and a 10 mm. wrench than it will take to change the lever.
Thanks guys,
I found me this one on ebay
Honda VTR1000 F Super Hawk Clutch Lever 98 05 | eBay
Look good to you guys?
Thanks.
Thanks.
My 2 cents is to look for brake and clutch together. You'll save on shipping and bikes inherently/inevidably tip, breaking levers. This leaves you stranded til a new one comes so always keep spares.
Something like this Honda VFR 800 VFR800A Inteceptor VTR 1000 Black Brake Clutch Hand Lever Set | eBay
Surfer, I mention the manual because it seems if someone is even asking the question about the lever, then yeah, there will be surprises.
Mem, take pics and ask questions. Knowledge abounds on here and you have to start learning somewhere.
My advice exactly. In fact, I just did this last week and the psychomotogear levers work just fine. If you don't like black they have them in plain old polished aluminum, which is what I bought.
Honda VFR 800 VFR800A Inteceptor VTR 1000 Polish Brake Clutch Hand Lever Set | eBay
For about 10 bucks more you can get the cheap Chi-nee Pazzo knockoffs, but there is nothing wrong with the stock style levers.
