replacing bent rim (ft)
Old 02-07-2006 | 11:24 PM
apbrian112's Avatar
apbrian112
hey guys (and gals), like the description says... i got a bent front rim, it's way off center. the only reason i've held off on replacing it is because it doesn't wobble at all and it hasn't really bothered me. but now i'm planning on replacing it soon (front tires due for a change) and i'm wondering if i have to replace the spacers and axle as well. any info would be great. thanks.
ps... if anyone has a straight front rim e-mail me at apbrian112@hotmail.com with how much you want including shipping to 91206. thx!
-brian-
Old 02-08-2006 | 12:05 AM
marmaladedad's Avatar
Hmm?
If the spacers and axle are not bent, then you can reuse them.
Old 02-08-2006 | 03:13 AM
RonVTR's Avatar
RonVTR
Re: replacing bent rim (ft)
If you can't find a wheel, check out one of the wheel repair companies...
Here's one that I found after a quick Google search...
http://www.framestraightsystem.com/Alloywheel.htm
I'm shure their are others closer to you. I found one here in WA that repaired a M/C wheel for me for about $80.
Good Luck
Old 02-08-2006 | 02:51 PM
mdbuehler's Avatar
mdbuehler
As soon as my bolt problem is resolved on the CBR wheel, I'll have a front rim up on ebay (12k miles on it).
I'll keep ya posted.
Old 02-08-2006 | 07:19 PM
RonVTR's Avatar
RonVTR
I went back and checked... Here's the guy I used:
http://www.thewheelmaster.com/
He repaired my Dymag (I was rearended), and didn't even scratch the finish. Though I was off a bit on the cost... try $180, not the $80 as I previously quoted.
This may not be usefull as you can probably pick a used wheel for less than that.
Bandit400man
07-25-2013 10:02 AM
john3012
05-31-2011 07:42 PM
Texassuperhawk
02-28-2007 04:20 PM
calitoz
07-22-2006 08:05 AM
Randman
05-22-2006 06:18 PM
