Red Dot on Pirelli Tires - light or heavy?
Old 02-19-2012 | 12:46 PM
cliby's Avatar
Simple question. My first time with Pirellis (rosso corsas). They have 2 small red dots.
I'm used to one yellow dot on dunlops. I searched and have read conflicting things: is this the light or heavy spot of the rim. Dunlop puts in on their website. I can't find on the pirelli site. So does anyone know for sure which the red dots on pirellis are marking? Light , heavy or high spot on the tire.
thanks
Old 02-19-2012 | 02:12 PM
aja's Avatar
aja
Usually its heavy and opposites the valve stem, could be wrong though.
Old 02-19-2012 | 04:29 PM
Tormoz's Avatar
Tormoz is on a distinguished road
This from Motorcycle Tire/Tyre Tech 101 :
"Some PIRELLI tyres have a red dot on the sidewall. This indicates the lightest point, and should be positioned next to the valve."
Old 02-19-2012 | 06:42 PM
cliby's Avatar
that is the only reference I could find also. thanks guys
Old 02-19-2012 | 10:46 PM
...unless you have a static balancer, in which case I recommend balancing the wheel without the tire and then marking the heavy spot. Mark the inside of the rim with a sharpie and align the dot to that instead of the valve stem. 90% of the time the heaviest part is not at the valve stem.
Old 02-20-2012 | 07:44 AM
cliby's Avatar
thanks again. yes I use a balancer and do just as you suggest. and the heavy spot was about 70 degrees away from the valve stem.
Northman69
03-17-2013 07:27 AM
wormeater
11-11-2006 03:07 PM
Tempest
09-13-2006 01:01 AM
mikecronis
07-16-2006 08:44 PM
EngineNoO9
06-19-2006 10:55 AM
