Rear Turn Signals Always On?!
Old 07-26-2012 | 09:08 PM
Dan Hough's Avatar
Dan Hough is on a distinguished road
Maybe I'm a bit rusty since its been a while since I replaced turn signals, but....
I've replaced my front & rear signals with some Emgo's (incandescent), and wired them up as directed.
TWO problems:
The rear signals are always lit (as a running light) & they are blinking fast.
After a lot of reading & searching, I've not found any solutions.....
Anyone???
Old 07-26-2012 | 09:40 PM
The back ones cant be on all the time since they are not red which is the only legal tail color. Is everything else working properly?
They would blink fast if you swapped to all LED lights & you would need a different flasher.
Old 07-26-2012 | 09:50 PM
Dan Hough's Avatar
I do know the rear should NOT be on, and they are amber. No LED's, just the standard incandescence....
Old 07-26-2012 | 10:39 PM
Ok then I'm gonna say you dun screwed up the wiring. They should only be 2 wires. Did you replace all 4 sigs or just the rear?
Also, if its flashing fast its due to less resistance so maybe one isnt grounding?
Old 07-27-2012 | 02:25 AM
Most likely that they are blinking very fast... Even if they are incandescents the stock relay wont work very well if they use less W than stock... So a relay for LED's should fix it... Note that the relay in itself doesn't care about LED vs incandescents, it's just that people call them "LED relay" when they are load independant, they work exactly the same...
Old 07-27-2012 | 11:01 AM
Jack Flash's Avatar
Well take off, eh.
You have a bad ground. You need to check your wiring
again like SmokinJoe said. If your still not sure, take a pic
of your installation, and post it so we can see your wiring.
Then we'll be able to help you better..;o)
Old 07-27-2012 | 02:46 PM
You guy do realize that bad grounding would lead to the signals being always off right? No ground = no current = no light...
But it doesn't mean it's not likely the wiring is messed up...
Old 07-27-2012 | 04:37 PM
I thought bad ground was the answer to everything electrical.
Old 07-27-2012 | 06:12 PM
BeerHunter's Avatar
Slacker
How many wires coming out from each of the new signals, 2 wire single filament bulbs or 3 wire dual filament? Did you install the dual filament type on the rear? What is the behavior of the front signal lights?
Old 07-27-2012 | 07:53 PM
Dan Hough's Avatar
Ok... Both sets are 3 wires, with dual filament bulb. The fronts use all 3 because of the running lights. The rear just eliminates the use of the running light wire.
As of now, the fronts function fine, but fast. The rear are on all the time like the front running lights, and they blink like the are supposed to.
The ground is fine, and everything works fine with the OEM signals.
I've read I need a "Load Equalizer" or LED style relay. Basically the new lights don't pull as many watts as the originals, and the relay balances it out.
Does anyone agree the relay is the solution?
Old 07-27-2012 | 08:37 PM
Yeah, relay is the solution. Or a change of expectations... having seizure inducing blinkers may ward off potential rear ends
Perhaps you used the wrong wire in the rear? Try leaving the grounds, but connecting the other wires. I'm totally guessing here, you may find that the load changes as well and the lights blink more normal. Or the electric gnomes in my head aren't visualizing it correctly... it was a long Friday.
Old 07-27-2012 | 08:50 PM
saige's Avatar
the boss
maybe the past ower re-wired it and is jumping off the tag light to keep it on.
if the rear turn signals have 3 wires,it is wrong,should only be 2 per rear signal.
Old 07-27-2012 | 08:54 PM
Dan Hough's Avatar
One more tid bit.... Much like when a bulb is out, the dash board signal is on. Both are on when both new pairs are hooked up, only one if a single new pair are connected.
Ive seen basic LED relays on ebay for less than $10..... would these work?
LED Turn Signal Load Equalizer Flash Rate Controller -ONE UNIT FIXES TWO LIGHTS! | eBay
Looks like with these I would only need two... one in fron & one in rear.
Old 07-27-2012 | 09:30 PM
saige's Avatar
the boss
go to cyclegear if there is one around,and get the relay from there that is for honda.
its a led relay.it will work.
Old 07-27-2012 | 09:57 PM
BeerHunter's Avatar
Slacker
Does the front signal flash dim while the rear is brighter?
A new signal relay will not fix your problem. You have reversed the ground wire and the running light wire on the FRONT signals. Swap those two pairs on both sides and power it all up again. Green swap with White striped wire on the harness side.
Old 08-03-2012 | 08:21 PM
Dan Hough's Avatar
BeerHunter, you win! I have no idea why or how the grounds wee switched, as I only matched the previous set-up. I had already wired in the relay when I read your post. Immediate fix. Now I just need to remove the relays, as I dont think they did a damn thing. Other than a slightly faster blink, ALL other issues are gone.
Thank You Thank You!
johnclopp85
05-13-2009 08:20 AM
marmaladedad
04-24-2006 08:37 PM
thegreep
02-16-2006 07:00 PM
mikecronis
05-03-2005 06:09 PM
