Rear brake mounting?
I recently found while sitting on an incline & applying the rear brake to hold the bike steady that my VTR1000 noticeably rolled backwards. On investigation I found that there doesn't appear to be anything to stop the caliper mount from rotating backwards until the brake pipe reaches maximum stretch.
Sure, there's a lug welded onto the swing arm to stop the caliper from rotating forward & the caliper mount has a big slot in it that looks as if it should mate with something -- but there's nothing there on my bike...
Surely this can't be right?? (my Kawasaki GT750 has a huge brake torque arm to control the rear brake :-) -- is there something missing from the assembly?
BR
David.
BR
David.
BR
David.
BR
David.
Um, really... Insert lug "A" into slot "B".. When the back tire is mounted, the caliper slot goes over that lug on the swing arm.
Yep dead obvious when I take the time to look at the thing properly in daylight :-) Forgive my surprise but this is how I recently took delivery of the new-to-me machine from the dealer, who is now *very* embarrassed...
This same thing happened to me when I had a new tire put on once.. the rear brake line stretched when the caliper rolled around the hub, so I made the local shop replace the rear brake line.. got a steel braided line gratis.... May I suggest? I wouldnt trust the brake lines integrity now... those ends are just crimped on, and may have come loose.
superhawkfanboy88
08-31-2012 12:38 AM
YellowHawk2k1
06-24-2007 10:00 PM
