rc51 f/end
Old 04-18-2012 | 03:00 AM
erno's Avatar
erno
rc51 f/end
Hi guys
Im in the process in finalizing my parts for the swap
I am using cbr1000rr f/wheel,but could not source the correct OD bearing
To fit the cbr wheel and a modified inner spacer
So, I know the rc51 bearing is 2mm wider than the cbr
My question is will the extra 2mm width make a difference to the finished f/end
Or do I make up 2 new front spacers 2mm less each side to counter balance
out the bearing width
Advice would be appreciated
cheers
Old 04-18-2012 | 09:05 AM
If all the other measurements are the same you can make it up with spacers, the bearings work the same way, no worries mate.
Old 04-18-2012 | 08:28 PM
erno's Avatar
erno
Thanks for the reply
cheers
gps
08-25-2007 02:50 PM
James Avrit
07-27-2007 11:18 AM
Dominion
07-23-2007 10:52 AM
cliby
06-10-2007 07:50 PM
bigbob65
05-14-2007 01:22 PM
