RC 51 Wont run !!!!!
Hey was just wondering if anyone could help ? Having problems with a friends 2001 RC51 at low end revs between 2 and 3000 rpm the bike is dying for a second its like shutting off the ignition for a second then will pull through the rest of the rev range fine !!!! have tried a few things like wiring connections all ok had the tank off checked everything in the airbox is fine cdi is ok no damage to unit or wiring running out of things to try any help would be apprecated
[quote=SlowHAWK;169270]You might wanna try over at Speedzilla.... theres a pretty active RC51 forum over there where you might find some people a bit more familiar with the RC51
Hey SlowHawk thanks ill check that site and see if someone can help
Also were you doing a SSS conversion ???? i have seen some of the posts regarding Caltoz conversion i am in the process of doing one right now and have found your measurements to be more true !!!
vermontzx6r
05-09-2009 01:50 PM
