R/R - Stator & battery diganosis.
So I got my R/R swapped out with a mosfet one. (from a zx10)
And it works, I now at idle get 13.4V etc and it seems to behave just fine when a voltmeter is attached.
However I went on a test ride and I still got a flickering dash.
So is it just that my battery is toast (I expect it is) or should the R/R keep this from happening when the bike is running?
Or perhaps my stator is iffy?
i know that with my srad the gauges would die til i got to a high enough rpm (5K). turns out what i thought was a bad RR turned out to be a bad stator. its easy to check the stator. just ohm out the 3 phases and see if they are in spec. one of my phases were out by .1 ohms. put a new stator had no problems after that.
Anto
08-27-2012 03:57 PM
