Question for engine builders.
When I torque down my rod bolts to check the oil clearance, can I reuse the old rod bolts then replace with the new ones once I have the correct bearing selected?
Sorry, I didn't read that clearly. You will not have to torque those to full torque to check clearance, and it is a PITA anyway. Got 30-40ft lbs with the old ones to check you clearances. Use new ones when you put it back together.
P.S. I shot my mouth off without reading through your post all the way.
mootsmadness
09-11-2011 11:51 AM
REDVTR1000
04-25-2008 01:14 PM
