petcock diaphragm
petcock diaphragm
I have been looking for information about the petcock diaphragm in the forum and the manual. Specifically diagnosing a torn or malfunctioning diaphragm. What are the symptoms of a torn/damaged diaphragm?
I am getting a little gas in the vacuum lines I put in to sync the carburetors. I don't want to replace a part that isn't broken. Advice?
Seeing as how I have had to replace two of them, my experience both times involved fuel starvation to the engine. It would start to lose power and misfire while cruising down the highway. It often started slowly, a quick pull of the clutch and some revs would clean it out and you'd keep going. Over time it gets worse, to the point that the engine cuts out (not a good thing when you're in the process of passing a rig!!!!!). It would idle ok but misfire and bog when trying to give it gas. It had me stumped the first time (thought I had bad gas initially) but I quickly diagnosed it the second. IN the end, very erratic running that gets progressively worse.
Hope this helps
Hope this helps
Hope this helps
Hope this helps
idle speed at operating temp is 1300rpm.
If the choke/enricher is malfunctioning can it cause this?
this started happening after I synced the carburetors. I synchronized the carburetors because the bike was farting/coughing in 1st and 2nd gear at 3500 to 4000 rpm. constant speed.
Could be coincidence.
