oil capacity?
oil capacity
The Honda shop manual says 4.1 US quarts with a filter change. Just FYI, I dropped the oil pan to clean the pan and oil strainer once and it took 5.5 quarts to get the oil in the inspection window to a decent level. (P.S. -if you don't have a shop manual, I got mine off e-bay for $20 - worth every penney!)
There's a shop manual here on the forum free for download.
https://www.superhawkforum.com/forum...ead.php?t=3673
Fifteenth item down from the top in the first post. When you get to the link, the little picture is of an aftermarket manual but the download is the real thing from Honda.
5.5 is a LOT of oil. If the bike is on its sidestand, then yes, it's possible to put in that much.
Remember, the bike is supposed to be standing straight when you pour the oil in.
I usually get about 3.7 quarts. A little bit more when changing the oil filter.
Kickstand left, sight glass on the right for me too. Hence, when it's on the kickstand and left of straight up and down, you would need to put more oil into it to read on the sight glass.
About 4 qts. without a filter change and a little over 4 qts. with a fiter change for me.
Lol I found out the hard way that these bikes are nearly impossible to even push-start....damn thing would just crank over once and then lock up the back tire....had to pull it with another bike and pop the clutch at around 20 mph and it BARELY started
And yeah with a filter change, mine took one of those 4 quart...or 4 liter...whatever it was...jugs of Spectro and was right at the perfect level....made it much easier to fill up since my sight-glass has a thin layer of spraypaint over it so you can BARELY see through it :-x
No, it was me that was trippin. Too little time with the bikes during these loooooong NY winters isn't good on this hobby/passion of motorcycling. Damn, I wonder how rusty I'll be riding in the spring...
Yeah, the 4Q container (1 Gallon) is 3.7... Litres. The Haynes calls for 3.9L IIRC. I am looking for .2L of Max. Oil...anyone, anyone?! Why couldn't they make the capacity 1 Gallon, for US bikes? The world does revolve around North America doesn't it?
So if you hold your breath while changing the oil, and if the sun is in the east even thought the day is done, will the front tire feel the pain of not having the right type of oil in the bike? Just wondering...
I drain the oil, change the filter every time (way to cheap not to) add 3.5 quarts, crank her up and run for 3-5 mins, shut off wait 2-3 mins then check level (while balancing her straight up and down with one had, kneeling PITA) usually have to add about .3 to .4 more....for a grand total of 3.8 to3.9 quarts of synthetic Mobil 1 Gold Cap 15w50....(maybe that will kick off another what kind of oil do you guys use thread?) LOL.....
Blackbetty
06-01-2013 02:01 AM
CentralCoaster
07-21-2008 11:54 PM
