Oil In Airbox
Oil In Airbox
I recently bought a 2000 Superhawk with 20,000 miles.It had been sitting for a while and didn't run well at low speed.I installed some slip ons a jet kit and a K&N filter and have the bike running well but the airbox is getting a lot of oil in it.Also when I unscrew the oil fill plug while running theres a lot of pressure coming out.Normally I would think worn rings, but theres zero smoke out the exaust and the plugs didn't show any oil on them.Any ideas?
There is a drain hose for the air box that needs to be uncapped once and a while. Left front, near the chin mount. If the plug is gone, I would clean the air box and replace the filter. I would then keep an eye on it. The pressure pulse is normal. Caused by displaced air from piston movement.
hi..
There is a strain hose for the air box that needs to be uncapped once and a while. Remaining front side, near the chin area install. If the connect is gone, I would fresh the air box and substitute the narrow. I would then keep an eye on it. The stress beat is regular. Due to removed air from aide activity.
I have noticed a small amount of oil drainage down the left side of the bike after it sits from a ride. It looks like it is coming up from under the tank just infront of the seat. Could this be caused by the same problem of not opening the drain? I cannot find any gaskets or seals leaking anywhere on the engine.
Don't want to hyjack the threat just sounds like the similar problem I am having.
strange...I don't have an airbox drain tube. I have 2 from the fuel tank and 1 from the coolant bottle. No mention of it in the manual either and nowhere for it to go on the airbox. I have come across these drain hoses on other bikes but definately not on my VTR
+1 Kurt999
On my 2001 VTR, the only drain tubes located at the front left side of the motor and which fit into the chin fairing are: a vent tube from the fuel tank, a drain tube from the fuel tank, a drain tube from the coolant pump weep hole and a drain tube from the coolant reservoir overflow. The drain tube from the coolant pump weep hole was added after the 1998 model year. There are vent tubes or passages from the cylinder head covers, carburettors and PAIR system which attach to or are part of the air box but there is no drain tube from the air box for oil. Any oil mist from the cylinder head covers should collect in the plastic bottle in the air box and any vapour should be drawn into the carburettors but it's not abnormal to have a trace amount of oil in the air box.
+1 Kurt999
But yes, there is definately no drain tube from the airbox (or anywhere else) for oil, even on non PAIR equiped bikes.
hi..
Question...is this guy ^^^^^ for real?
And my 01 Cali Hawk has no drain from the airbox nor did my 05. As the authoritative 8541Hawk stated, a bit of oil in the box is no big deal as is a bit of cc pressure.
You may get a bit of spray around the airbox but thats no big deal.
spladle160
03-15-2010 09:42 AM
CNI Dawg
01-24-2008 09:59 PM
