Odd problem looking for suggestions
Old 04-16-2010, 09:52 AM
  #31
Old Yeller's Avatar
-10,001
you guys suck.
Adam,
Have you found your problem yet? it was you that started this nonsense, wasn't it?
Old Yeller is offline
  #32
Old Yeller's Avatar
(just to be clear...the winks meant it was sarsasm....just kidding and no offense intended to anyone)
Old 04-16-2010, 10:03 AM
  #33
Always Learning
AdamK's Avatar
HAH.. Thanks Old Yeller, yes, it was in fact the main fuse. Now, what cause it to go... . I printed out the PDF that Tweety was referring too in his response and will hopefully have an opportunity this weekend to tear it down and check it out.
Thanks, and it is expected... I probably could have searched longer but I gave up and took the easy route by asking first. I'll try not to do it again
AdamK is offline
Old 04-16-2010, 10:33 AM
  #34
psyclown's Avatar
psyclown is on a distinguished road
Tweety is a dick
psyclown is offline
Old 04-16-2010, 10:55 AM
  #35
Originally Posted by psyclown
Tweety is a dick
I know I have a wierd sense of humour, but your's are even stranger... Unless you actually mean that to be taken literaly... If so please explain why...
Tweety is offline
Old 04-16-2010, 11:22 AM
  #36
drew_c14's Avatar
Just remember Tweety, people love to hear themselves talk on the internet.
drew_c14 is offline
Old 04-16-2010, 11:30 AM
  #37
Yeah... And I kind of expect rudeness... Not outright stupidity like psyclown here displayed (unless he is kidding, which I doubt as it would be way beyond very odd, if so consider it a failed joke...)
Tweety is offline
Old 04-16-2010, 08:15 PM
  #38
[quote=Tweety;262241]Yeah... And I kind of respect rudeness... Not outright stupidity like psyclown here displayed.quote]
OK now that we got that cleaned up.
Newbies! Look at the post counts for these senior members. We have answered the same ******* question a thousand times. Some of the these members answered the same questions for me. Once!
nuhawk is offline
Old 04-17-2010, 07:29 AM
  #39
pragmatic anarchist
peterpanic's Avatar
Tweety is a dick
You've got to be kidding. Richard Tweety? Really? That's awesome!
peterpanic is offline
Old 04-28-2010, 12:20 AM
  #40
MP660's Avatar
MP660 is on a distinguished road
To the best of my understanding, the rectifier regulates the power sent to the main fuse. So when the rectifier goes out (which is a common problem on the SH), the main fuse receives an overdose of wattage therefore causing it to split. So yah, the bike will shut down instantly, no power, none, zip. That's what happened with mine, just speaking from my own experience, but I was lucky enough to be riding in day light when it happened. I didn't know the regulator could be a problem at the time, so I first replaced the fuse and it ran for 30 seconds before blowing again.
MP660 is offline
Old 04-28-2010, 12:44 AM
  #41
residentg's Avatar
regulator "regulates" voltage to a specified value by shunting off voltage above a perdetermined value, in this case somewhere in the mid 13's VAC
rectifier "converts" VAC to VDC.
that is why it is called a regulator / recitifier or RR, it is actually 2 unified systems.
residentg is offline
Old 04-28-2010, 05:22 AM
  #42
Christian_man30's Avatar
Christian_man30 is an unknown quantity at this point
OK, this is really freakin rediculous...COMPLETELY....New Member or Old Member....some people dont know the accronyms for some of the PARTS/PROCESSES/TOOLS or whatever the case may be on this site or for much of anything at that matter.
And for people to get on here and bad mouth someone for no good reason......GROW UP. Relax, step back & add a "LINK" to help them if you know where it is on this site...or anywhere else, regardless of whatever ill-fathomed thoughts you have in your MIND that you are better cause you have the knowledge now (BUT DIDNT AT SOMETIME) and where in the same position at some point and time in your life, when you had (what you thought to be) a severe problem and didnt know where to turn to for the CORRECT ANSWER because you were paranoid that it might be CATASTROPHIC!
Chill people....NEW MEMBER or OLD MEMBER.
Cant we all just get along.
P.S. no one makes you read the posts/blogs anyway......
Christian_man30 is offline
Old 04-28-2010, 06:38 AM
  #43
residentg's Avatar
Do you take issue with my explaination of RR above?
bass4dude
07-05-2011 08:23 PM
dshakes
05-19-2010 07:39 AM
HawkFanatic
01-27-2009 06:31 PM
Zedicus
09-03-2008 08:00 AM
Anto
06-20-2007 06:20 AM
Quick Reply: Odd problem looking for suggestions
