Not Starting
Not Starting
Took the tank off for paint. Got everything back together and the only way I can get it to fire is pulling on the choke lever. It will stay running only momentarily. I have a battery charger on i because I keep draining the battery trying to start it. Could I just have to wait until the fuel pump kicks enough fuel back into the carb? Whats going on? It ran fine before I took apart for paint.
No fuel pump on this bike- it's all gravity fed. Search PVLIR- your hoses to the fuel tank are probably not hooked up correctly if you took it off. It's very common. The bottom nipple of the petcock should not have a hose coming from it, and the little hose should be attached to horizontal nipple on the back of the petcock
I have two "bigger" dia. hoses coming off of either side of the fuel shut off valve. There was alsoa "small" and a "large" dia. hose towards the rear of the tank. I got those on. And the only other thing I discoed was the electronic thingamabob under the center of the tank. Thats plugged in as well.
https://www.superhawkforum.com/forum...es-pics-22048/
Letsrideinsc
09-03-2009 04:16 PM
