not starting
Old 03-04-2010 | 03:45 PM
offroad_rider2008's Avatar
not starting
hey guys, Im having troubles gettin my bike to start, i have a battery tender on it had it on there, been starting it every day or every cpl. days since i got it but for the last 3 days it hasnt started, its been really cold but it would at least start after a lil bit of coaxing, but not now it tried a cpl times but it just wont kick off, i have lke a 3 day window of really good riding days and would like to put a few miles on it, ty
Old 03-04-2010 | 04:50 PM
zmaniv's Avatar
Check the obvious stuff, make sure it is not in gear, make sure the kill switch is not on, check for gas, then check for spark try jumping with a car battery.
Old 03-04-2010 | 07:05 PM
been doing that all afternoon, didnt check 4 spark because every once in awhile it would try to start then right back to just turning over, the r/r is finned so im guessing its been replaced was running just fine after a lil bit of tryin to get it started, but today it was mid 50's so it wasnt to cold for it even had it out in sunshine
tried draining carbs and using starting fluid, but to no avail! frustration setting in
Old 03-04-2010 | 07:14 PM
zmaniv's Avatar
Did you put the vacuum line back onto the petcock in the correct place?
If not it wont open and allow fuel into the carbs.
Old 03-05-2010 | 10:49 AM
all lines are on the petcock, seems to be getting fuel, drained the carbs again just to make sure, it really tries just about the time youre ready to stop pushing the button, the just goes back to turning over, every once in awhile ill get a backfire but thats about it. Im about at the end of my rope here, how would i check the r/r if i dont have an ohm meter? would there be anything else im not trying? I know that it will be the last thing i check, lol, but im running out of ideas, thanks guys, im about to go nuts, got some awesome weather goin on and im missing out on it
Old 03-05-2010 | 11:44 AM
Where on the petcock? the vacuum line goes on the back - right, not on the bottom.
(it looks like it should go on the bottom, but that is the vent, the correct place is hidden)
Old 03-07-2010 | 07:48 PM
Hawknut's Avatar
Hawknut
I bet you flooded it out.How hot did you let it get?It takes mine several miles to get everything up to temp.Sounds like was getting harder and harder to start.Get yourself a fresh set of plugs and while the old ones are out check for spark or even before you take the old ones out.Your much better off putting some Sta-Bil in the tank and putting her to bed than letting her take short naps.
Old 03-08-2010 | 09:51 AM
was told that i lost spark had to put her in my buddies shop to check thru the boxes and find the culprit, hoping itll be home by the w/e
Old 05-16-2011 | 12:37 PM
Ryder3610's Avatar
Ryder3610 is on a distinguished road
What was the problem
Rdm1776
07-22-2013 01:26 PM
crow
02-19-2012 10:39 AM
AKBadRep
05-31-2011 12:14 PM
Letsrideinsc
09-03-2009 04:16 PM
viperkillertt
08-28-2009 08:13 PM
