Noob hereHow does the TPS go back together
Hello guys, I have just bought a Firestorm (I'm in the UK) and it needs a few bit putting back on. I was wrestling with the carbs to put them on only to realise once I did get them on I forgot to screw in the chokes. Trying to get them back of was difficult so I thought, hmm easy, I'l just undo this side plate holding the two carbs together and ping! What I believe to be parts of the TPS popped out, a spring and a plastic piece which I pressume the spring rotates?
My question, how do I put it back together?
Many thanks,
Joe
Many thanks,
Joe
Joe,
The best way to do this is to pull the carbs, slot the shear screws holding on the TPS (with a Dremel), and use a flat-blade screwdriver to remove the TPS bolts. You need to CAREFULLY put it back on. Many guys have broken theirs attempting to reinstall it. There is a pin that has to go into a slot on the linkage. Miss the slot and try to tighten it? Voila, broken TPS.
Once the carbs are together, install the carb heating hoses, choke cables, and throttle cables. Then install the carbs on the motor.
The carbs will, and must, go on as a set. Try some silicone spray to aid getting them into the intake boots. Do one, then the other. Ensure they are fully seated and then tighten the clamps.
Since you have loosened the connecting brackets you MUST do a carb sync and adjust the TPS once the bike is running again.
Here is the microfiche of the carb assembly, hope this helps http://fiche.ronayers.com/Index.cfm/...ARBURETOR_ASSY
Many thanks,
Joe
Many thanks,
Joe
thanks, nathan
If the spring and plastic came off, then your TPS is broken. Don't bother trying to glue it, it won't hold
I broke mine messing with the carbs too.
The only good news is the bike will run fine without it. I put maybe 1500 miles on mine before the replacement showed up.
You might also be able to get one of the car units to fit on there. They appear to be exactly the same except the plug comes off at a different angle. They're wayy cheaper. I don't know if there's enough slack in the wire harness or not.
Hey guys, I forgot I put this up here. After much confusion and many head scratches I realised it was bust! I managed to get another of a breakers for £18 delivered which was annoying but not the end of the world. Just got to put it all back carefully now...
Joe
Joe
Shane702
06-01-2013 03:03 PM
skoshere
04-09-2009 10:03 AM
VTRBandit
02-16-2007 05:09 PM
