New Chain Info and Question
Old 04-24-2007 | 09:55 AM
bkelsey's Avatar
bkelsey
After 16K, the stock chain on my 02 was getting a little kinky (No, not ball-gag and zipper mask kinky).
I found an RK X-ring chain (530XSO102) at MAW for $61 ($20 cheaper than anywhere else I looked ?)
http://www.mawonline.com/rk.htm#Chains
I was under the assumption that it came with only a rivet type link. That was fine, but I also ordered a cheap ($16 !)chain riveting tool
http://www.mikesxs.net/mikesxs-tools...ategory_id=7.1
So, I ordered a clip type master link as well, just in case the tool sucked. It worked fine and the chain came with both type links anyway, so now I've got 2 (link type) spares.
I also changed out the front sprocket (16 tooth) this time, I'll do both with the next chain.
Anyway, the only odd thing with the chain, is that it appears that I don't have as much adjustment (a few grooves on the adjusters worth) with this chain as I did when the stocker was new. Has anyone else experienced this?
Old 04-24-2007 | 09:01 PM
Otto Man's Avatar
How did you measure for the new chain? You can't simply lay the old and new next to each other and cut, because the old chain is stretched (Not really, but thats the real generic term for it). You have to count the links to make it the same. If you have a really worn chain, you'll find the newer chain is alot shorter than the old one, if both chains contain the same number of links.
Old 04-25-2007 | 06:46 AM
bkelsey's Avatar
bkelsey
No measuring. Stock sized sprockets, so I ordered and got 102 links.
What I'm saying is that I thought the chain would be shorter than it is, compared to the stocker.
Old 04-25-2007 | 07:24 AM
autoteach's Avatar
Your sprockets could be worn. Just a guess.
Bill
Patton303
05-24-2012 09:28 AM
strathern
09-25-2011 02:38 AM
Reason
07-18-2011 02:33 PM
Jens_denmark
07-23-2010 12:11 PM
Truckinduc
09-22-2009 06:22 PM
