Neutral switch problems
New to the forum, heres a problem Im having. When I first start the bike in the morning with it in neutral and stand down the neutral light will be illuminated while engine still cool, BUT then once the bike gets warmed up the bike will no longer have the neutral light illuminated when its in neutral unless the bike is leaning to the left like way left
NO the bike wont stay on with the stand down after warm up. I just dont understand why it only does it after warm up and but also the bike AFTER WARM UP the light will illuminate if i lean the bike to the left.>?
Most likely because the switch is on the left side of the bike? And since the neutral switch is either gummed up or faulty, it won't run on the sidestand, as the clutch/sidestand switch in conjunction with the faulty switch will kill the bike, thinking it's in gear...
inderocker
04-26-2010 07:44 PM
