Need help again
Need help again
So i am at witts end with this electrical issue, after doing some wiring repair still the SH will not start! I have tested the R/R, the battery, the starter, the selionoid, just about everything except the stator! all good so far. the bike will turn a crank or two then it stops and makes a wining noise like the battery is to low to start. It will start with a batt charger on it so something is draining the battery when u turn the key on. Any ideas?
I doubt anything will drain the battery that quickly when you turn the key on that it prevents it from starting.
I would make sure ALL connections and switches in the starting circuit are in good working order. It is also possible you have a battery with a dead cell. When this happens they can still read a good voltage but have no grunt.
I took it to an auto parts store, he said it tested good under a load. Don't know how accurate it was, i think i'm gonna buy a new battery anyways if thats not it than i dunno... Thanks for the info guys hopefully i'll be riding again soon.
Do you know the procedure to locate what is referred to as parasitic draw?
Well i feel like a f****** tard, about two weeks ago i installed an emission removal kit, removed alot of trash. On the left side of the airbox i removed a vaccum line and did not cover it. Bike runs like a top now. Sorry fellas! But thank you for all the help and suggestion's
Judolisa
04-30-2010 04:55 AM
BiggDaddyKool
02-06-2008 08:50 PM
