need advice on engine hesitation/knocking sound
#61
now why are you not adjusting at idle after carb sync like you're supposed to, rather than landing on someone else's arbitrary numbers that assumes front and rear are equal?
#62
Well this set up will work but once again the information I am passing along came directly from Dan Kyle. If you don't know who he is, well here is a quick blurb from his site: http://www.kyleusa.com/Home_Page.php
Founded November 10, 1997 by Dan Kyle, a master mechanic, who has built a reputation for blazingly fast and utterly reliable engines that have won 5 AMA National Roadracing Championships. Dan was crew chief and engine builder for the highly successful Erion Racing and Two Brothers Racing teams. He has prepared engines for riders Rich Oliver, Fred Merkel, Larry Pegram, Michael Barnes, Andrew Stroud, John Kocinski, and other champions. Dan has twice been awarded the AMA Tuner Of The Year.
So I'll just touch on a couple of quick points. If you want to believe the advice, fine. If you think it's wrong and want to go your own way, that is just fine also.
First, removing the restriction from the header. It is not a good idea. On back to back dyno runs the engine made less power with it removed.
Installing a jet kit. There really is no need. The factory needles are very good, they just need to be shimmed up a bit and make as much, if not more power, with a better curve than either the FactoryPro or DynoJet kits. The only needles the work any better are the HRC units but they are pretty much impossible to find anymore. The kit also has a couple of other tricks in it but hell I can't get you guys to believe this simple set up so why should I beat my head against the wall by trying to defend the other things that HRC did (and yes I run an HRC kit in my bike).
These setting are for a stock motor and if you make major modifications things will change but for the average member you can get as good if not better performance by installing $10 worth of pilot jets and a couple of washers instead of over $100 for a jet kit.
Anyway, when my hawk started acting up, I was basically at the mercy of opinions and advice of those on this forum to get it back to running well. Somewhere between here and the internet, I got the info posted in my signature which essentially erased the problems, and of course, I've since recommend this group of settings to others. Lord i apologize for that. Do I know which ones were critical and which were not? NO, because I did them all at once. Rot Roe!
When I look at Factory Pro and their products and recommendations, it seems as if they have extensive experience with improving the SH, and it makes you want to buy the shifter upgrade, ignition advancer, etc., and follow their recommendations which supposedly have been documented well beyond my expertise and understanding. If I had the financial means, i would like to make some of these improvements because, for example, I think the shifting is clunk and annoying, and to eliminate this would be certainly help.
i will take your advice on the #48s as well as the tool to adjust at idle to see if it gives me a little more juice, and because in helping Steve29 pull his carbs no less than ten times, it's no longer and issue for me mechanically. So thanks for the help and sharing your knowledge and experience. Apersheate it!
#63
Is that compliment, consolation, or a combination thereof? If you keep the cup full, you can't learn anything because you already know it all. If you keep the cup half empty, there is always room for growth through learning. In my case, maybe the cup is leaking. If that's the case, it's just a matter of how fast and how long to ground zero. haha
I asked him to identify some of the parts on the table. He correctly identified a distributor and a carburetor, but when I held up an ECM (on-board computer), he said smugly, "That's a stereo".
When one of my students would tell me that I must know everything about cars, I would respond, "No I don't. I learn something new almost every day I'm teaching in the shop. And anyone who says they know everything there is to know about cars is a fool".
#64
About 20 or so years ago I was at a career fair at a high school to promote The Vocational Automotives program I was teaching at the Adult Ed campus. A 17 year old walked up to my display and told me he didn't need to take any auto classes since he already knew everything there was to know about cars, taught by his dad.
#65
Yeah nath, my students ran the gamut from exceptionally bright to mentally challenged to ex cons to guys on daytime release from juvie to fresh in the Country no-spik-English.
I'm sure you had many rewarding moments, as I did...as well as many times you were pulling your hair out.
And nath, when are you going to make MotoGP? You're over 500 posts away, but it seems like you're on here a lot. And I'm sure you're a much more ***** out rider than I am.
#66
motoGP? i didn't even realize there was such a thing. I guess if you live long enough you can accomplish anything. What award do i get for achieving MotoGP status?
Probably a "Big Mouth" T shirt or some ****, huh/
"***** out rider", i don't know about that. I still ride a pretty good pace i would say. I definitely don't cruise for sure. But nothing compared to my younger days when I fell off at least once every riding season.
"If ya ain't fallin off, ya ain't ridin", was my mantra. I lived by this religiously until I quit riding to spend more time with the family in 76'. Fortunately, after the 8 year hiatus from bikes, I have only had 4 get-offs on the street in 26 years. It's not hard to remember these for sure, but I don't want to recount the off-roaders. haha
#67
Getting the MotoGP moniker makes you a legend in your own mind, I think.
Maybe a t-shirt with Rossi's ugly mug on it...I certainly don't want to be associated with Valentino Rossi though. I mean he rides great, but other than that, I think he's just weird.
Jets vs Steelers game is turning into a nose picker. But I can guess who you're rooting for.
#68
your guess would be wrong because I root for underdogs, and just like to see a good game, but not seriously interested.
#69
http://www.thumperfaq.com/fuel_screw.htm
#71
Don't wanna **** ya off again, but what is your opinion of this article on air screws:
Well I haven't gotten pissed yet......
but to answer your question, it is pretty good but it is for a race set up, not a street bike.
The places where I disagree are as follows:
1) there is no need to turn the adjustment screw in until the engine almost dies. A slight drop (or 50rpm as the manual calls) out is plenty.
2) after turning the adjustment screw back out until the rpms peak you turn it out an additional 1\2 turn. While this does cause a slight loss in power, it prevents the engine from going lean if conditions change.
If you wanted to you could set it to peak but do you really want to carry an adjustment wrench with you and keep resetting the the adjustment for peak power throughout the day? It's not something I would want to do.
#72
good way to lean carbs out for for high altitude instead of worrying about jets too.
#73
I was cheering for Lorenzo all last season, and he prevailed. Although some of his victory celebrations were kind of...weird. I'm being politically correct here.
#74
Humidity has a big effect on idle air/fuel mixture. In the mid '70s when I was a tune-up mechanic, I quickly learned that if I adjusted the idle mixture using the lean best idle method on a day with normal humidity, the car would come back a week later when we had a Santa Ana condition with very dry humidity, the customer complaining of rough idle. So I started adding approximately 1/4 to 1/2 extra turn out (rich) on mixture screws past lean best idle, depending on the car. It varied slightly on different types of carbs, depending on how sensitive the mixture screw adjustment was. I never had a come back for rough idle after that.
There were idle CO specs that had to be met for smog check (usually about 2.5% CO max, at that time), so you didn't want to go to rich, but you wanted the customer to be happy.
#75
i have two brothers race,(says on the pipe??) it was really loud before the de-smoging... the needle in the carbs look good and diaphragms and slides.
checked the air screws they are stock.. never slotted .. so i am assuming the carbs are stock as well...
i got out my manual and was reading there is a note in there on main jet sizes and air screw setting.. it said the mains should be 172 and 175 opposed to 175 178. and the air screw tuned in 1/2 more form stock/factor set. if the bike is ridden at 2kmeters which is around 6500ft, which i am between 2700-6500 until i get off the mountain and i am in a heavy dew/rain climate. which makes the air heavy and the same as thin air in effect. that is the reason i have fairly stock jetting in my other bikes b/c they run rich around here, great down in the vally and load up on the mountain, i am wandering if this one will be the same. i am getting good fuel millage. averaging in the 40s. so ??? i don't know.
yes. i hate taking things apart a lot, over and over... i had a right angle tuning screw driver to adjust carbs like this but some one stole it out of the shop one day. i need to get another. and if i get into the carbs then i have to change them and then if it doesn't fun well take it apart again. and the bike runs good now except for the popping on decel.
were these bikes lean from the factory?
seem like people who ride to higher elevations may need not only to own a pilot screw adjustment tool, but to carry it with them. Probably could just stop along the road, turn the screw in a 1/2 turn and keep on gettin it into the clouds.
and, by the way, you're going to have to do something about that abysmal fuel mileage too. To correct that issue, just turn the throttle adjuster on the right clip-on with reckless abandon and exuberance. Not only does this correct fuel mileage, it also elicits other benefits like laughing and hollering to yourself, not unlike some of the homeless people walking the streets of any major city.
#76
#77
so, does this mean you should oversize jets and pilots and let the flo commander sort it all out, because if you didn't have enough fuel(OEM jets and Pilots) for say a K&N and gutted slip-ons, it wouldn't be able to deal well with the too lean condition? Or?
does the flo commander alleviate the need for a sync too and a special tool to adjust pilots?
#78
i have not had too much trouble with air/fuel screws on the street bike, i have had trouble when larger jet sizes are used. the altitudes come and go farely quickly, unless the on a parkway trip. the CV are good for the changes, i can feel the changes when i am on the mountain. we also have heavy humidity.
i ordered a new driver (motion pro) as my other one grew legs..
fuel millage, after the carb set up, i got 36. riding by myself, tires a bit more broke in. the more curvy roads were clear. because of the roads being tight here, i tend to stay in a gear or two and run the rpm range. which for me is about 4-7k(maybe higher if i pass) and i try to average 5k rpms or so. lower if i am on the hwy. i tend to ride as if i have no brakes, a habbit from traveling/riding classic and vintage bikes(which really have not brakes) momentum, engine braking, & good lines are key when riding those bikes... when i get into the sport bike mindset, harder corner acceleration, late braking in and my millage drops like a rock.
i read an old article on the SH from its release in the US. they stated that the avg. mileage was 33mpgs.. they talked alot about susp. and quoted quite a few time on what the SH designer said the bikes target was. i need to see if i can find the article again.
i know what you mean about riding "the pace", staying in a rhythm, and using engine braking and basically smooth accel and decel. I nullify the engine braking with neutral throttle and trailbrake typically, but like you, prefer the 5-7K range. You live in a perfect place for twisties. I've passed through that area quit a few times when i drove semi. Nice motorcycle country and a little longer riding season than up north too. I'm coming down and stay at your house for a while. haha
#79
Those questions tells me that you have no idea what an FC is... Go search, read, and then I'll answer questions... No point in doing it until then...
#80
What I think i know, to oversimplify, is that the FC controls rich/lean settings in both carbs, maybe a little like FI, and this seems that it would also dynamically sync them in the process since it would make 2 carbs act as one, but not sure.
No big deal though. Although it seems like a good concept, I really can't afford one right now anyway.
#81
well no ****! that's why i asked the freakin questions and I think they're good questions.
The FC is a purely mechanical solution, no intelligent electronics... And it has absolutely nothing to do with the pilotscrew... The adjustment made on that affects the carbs/bike just the same regardless of the FC...
The FC does affect sync, in the way that once you have sync'ed at "high idle" the effect of the FC keeps the carbs better in sync through the revband... Something along the lines of what you said as " 2 carbs, working as one"... But you still sync the same way, and you still need to do it just the same...
And if you want to adjust the pilotscrew, you still need the exact same tools...
And again, if you have the wrong size jet's, main or pilot, the bike will run like crap... FC or not... The FC is a finetune, and just like when you count the rotations on the pilotscrew and it gives you a hint that you should go one size up or down on the pilot, the FC gives you the same kind of hints on the main jet...
The FC doesn't replace any one part on the carbs, or bike... It complements a whole bunch of them... And combined with someone that has some feel for his own bike and owns a philipshead screwdriver it "replaces" a dynobench for basic setup...
I have written more in detail in an older thread... Might be an idea to read that...
What I was referencing in the first reply about the FC, was the leaning out/fattening for altitude changes... Just like you can change the tuning a bit for spring/fall/summer you can change it for altitude... The range of the FC is equivalent to roughly +/- one jet size on the main jet... Ie you are essentially riding around with let's say 180-185-190 jets in your bike if you have 185's in there... Like you said, oversimplified... But almost true...
I have a dynobench, a wideband/narrowband analyser, and a whole bunch of other tools... So far the FC has done more for the tuning of my bike than the rest of them have... Granted, the FC alone wouldn't have been a miracle, just useful... But combined with the rest of the tools to read the results, the FC is close to friggin magic...
#82
Eeaachhh, dang it... I'm just annoyed tonight...
According to your explanation, it seems that you still need to get all your ducks in a row before you can derive any benefits from the FC. Getting the right jets, needle settings, correct pilot number adjustment, etc., is the difficult part. It takes only a few minutes to sync and probably the same to adjust pilots if the tools works, once you have your setting correct, so i don't know if it's worth it for a little fine tuning. The fine tuning descriptor says it all for me. thanks for the expo. Sorry you're annoyed tonight. Tells you that it's time to grab a cold one and mellow out.
#83
I forgive you. At least we know you're not perfectly rational all the time! You are human after all!
The finetune is one thing... The others are the on-the-fly adjustment... And like I said, the ability to get hints on swapping the main jets a size up or down... Which is what makes it a "DIY dynobench"...
Trust me, the finetuning is the small part of the advantages...
Yeah, cold one it is... Or in my case a glass of 32 year old single malt... Jummie...
#84
Well... You are missing the good part...
For me, when I got the engine running smoothly, no popping, farting, or stalling, I thought, this is amazing. Now it's time to get to my favorite back road and bend some turns.
The SH has more torque than the bike I had before, an 88' 1000 hurricane @ 130hp, although it would do 160mph without any drama,i.e., like you doing a hundred. But i don't get much from hyper speed fast in a straight line any more, although it it is fun occasionally. The point is that having perfectly linear power from zero to 150 isn't something I'm **** about as long as the mid range torque is adequate for the twisties.
I would like to try one though just to feel it for myself. All the reviews I've read seem positive, but most IL4s.
#85
well your welcome anytime, haven't got my house up to pare, but will be living in it in the spring, historic down town hendersonville nc. i am originally from Summerset Co PA, little town called Addison, PA, above theYoughiogheny , so i know about the riding season up there, could not stand it.. loved the dual-sport there.
Youghiogheny, nice roads down there too. Used to do some camping at Spruce **** and some repelling and spelunking in the National Forest. I'd be plenty happy riding Somerset into West-by-god, a lot more accessible than where i'm at now, although I'm not complaining. There's some nice low traffic twisties around here thankfully.
You need a dual sport up here for sure. Then you don't have to whine about all that **** on the roads because it's ridable with a dual sport.
REDVTR1000
04-25-2008 01:14 PM
