need advice on engine hesitation/knocking sound
Old 01-20-2011 | 05:40 PM
  #31
nath981's Avatar
Originally Posted by r80gsman
well desmoged it, synced the carbs and took her out, running is night and day, it still back fires a bit but not too bad, it is also a little quieter. it looks like the carbs were it to at some point, screws were warn also i found some blue paint pen righting on the block. MG 50. ??? looks like speed shop markings or salvage yd. same color as in the airbox on the carb horns. (i write on bikes i work on to keep track of parts)
there is no flat spots in the rpm range with the K&N filter??. it pulls well at low rpms ,idle to 3k, the motor is much smoother. so i suspect a jet kit. i am just too lazy to open it up, "it ain't broke so i ain't fixen it". if she gets richer when i put in the oem style airfilter then i'll kinda now. but like i said she has a healthy supply of soot in the pipes
Did you check the air mixture screw? Getting the carbs out is easy if you use a strap to lift the front of the tank. If its backfiring, it's not right. I'd put the oem jets back in and shim the needles.
What's a healthy supply of soot? doesn't sound to healthy to me. Pull the plugs and see how they look.
It's your bike so naturally it's up to you.
Old 01-20-2011 | 06:44 PM
  #32
nath981's Avatar
i have always been told that the soot in the exhaust system is that way u tell if it is rich instead of the plugs with unleaded fuels. i was told that u want just a little on your finger when u press it,not wipe it, on the inside of the outlet pipe on the exhaust. and it should be brownish black on our finger or non but the pipe looks black, if you get a lot on your finger then it is too rich or if it is wet/pasty. it has always worked for me for the bmw airheads.
if it still backfires( more like throaty popping and it is minor compared to what it was) when i put the stock like filter in then i will break in-to the carbs.. after writing my last post, i was think, the backfires maybe to much vacuum/pulse in the intake, drawing fuel because of the high flow filter and exhaust, which would me a lit lean on the idle jet, meaning maybe stock idle jetting. i had this problem on my g/s after i put 1000cc jugs on and an open exhaust. i ended up going with an air screw adj richer...
plugs looked fine(not lean(white) not real rich(black), but with the ethanol in the fuel, this could be misleading.
shimming the needles. is there a know shim for doing this or does one make there own. i made one for the klr sherpa..(.035..??)from a washer
any how i will write the out come when i get my new filter, maybe it will come tomorrow
cheers
brownish exhaust is what mine looks like.
Shim: just a little washer(mic'd to .040).
I have a homemade oiled foam filter so i don't know how that would compare with a K&N, but I would guess similar flow rates. Esp since I cut the flap off the housing allowing greater flow too. Many on here say that K&N adversely affects running?
what for exhausts do you have?
I don't like to tear **** apart just for the hell of it either, however when i do get in there, I want to check everything out with a fine tooth comb, mostly so i can do it once only. Air mix, needles, diaphragms, jets, etc., anything and everything, kinda like a baseline for future reference.
Old 01-20-2011 | 07:03 PM
  #33
Originally Posted by nath981
pull vac lines out from between carbs and let them hang,
You mean the float bowl vent lines
Old 01-20-2011 | 07:08 PM
  #34
nath981's Avatar
haha. I thought all those little black rubber hoses under that big black box were vacuum lines. thanks for the correction.
Old 01-20-2011 | 07:28 PM
  #35
nath981's Avatar
i have two brothers race,(says on the pipe??) it was really loud before the de-smoging... the needle in the carbs look good and diaphragms and slides.
checked the air screws they are stock.. never slotted .. so i am assuming the carbs are stock as well...
i got out my manual and was reading there is a note in there on main jet sizes and air screw setting.. it said the mains should be 172 and 175 opposed to 175 178. and the air screw tuned in 1/2 more form stock/factor set. if the bike is ridden at 2kmeters which is around 6500ft, which i am between 2700-6500 until i get off the mountain and i am in a heavy dew/rain climate. which makes the air heavy and the same as thin air in effect. that is the reason i have fairly stock jetting in my other bikes b/c they run rich around here, great down in the vally and load up on the mountain, i am wandering if this one will be the same. i am getting good fuel millage. averaging in the 40s. so ??? i don't know.
yes. i hate taking things apart a lot, over and over... i had a right angle tuning screw driver to adjust carbs like this but some one stole it out of the shop one day. i need to get another. and if i get into the carbs then i have to change them and then if it doesn't fun well take it apart again. and the bike runs good now except for the popping on decel.
were these bikes lean from the factory?
air screws stock position likely. get em out of there, slot em and set them to 2.25 turns out as a base line setting.
shim .040in
these settings you're reading in the manual you can stick where the sun don't shine when you desmog , change exhaust system and who knows what else . Now you're in the lab experimenting unless someone else here rides those altitudos(spanish-haha). Then you can use those settings as a more realistic baseline and go from there.
lean form the factory is always a good assumption.
Old 01-20-2011 | 07:47 PM
  #36
Well on the VTRs I've messed with, the bike is lean on the bottom & mid-range and the top end is fine.
That is why I tell folks to start with just shimming the needles .040" and installing a #48 pilot jet (and for the record, this set up made the most power on Dan Kyles dyno when he did back to back runs with this set up, then a FactoryPro kit and then a DynoJet kit. Things might have changed as this was done in early '98 and FactoryPro and\or DynoJet may have made changes to there kit after these runs were done)
I am very close to sea level but it is a good starting point and all you need to buy is a set of pilot jets instead of an entire jet kit.
Old 01-20-2011 | 07:58 PM
  #37
nath981's Avatar
i never changed pilot jets, but I will order some #48s for sure. **** I was just in there to set the valves, but I didn't remove the carbs. No biggy, I'm gettin good at it, esp since I don't have to remove the tank =, makes it easy.
I'm riding at 2000ft to 3000ft.
Old 01-20-2011 | 08:01 PM
  #38
nath981's Avatar
see what i can get done tomorrow. then work on the bike. i may have some washers that small.. i have to look in the gun smithing stuff.
do some searching to see if you can find jetting/carb adjustments for 5000ft, and you can PM some forum members from denver.
Old 01-21-2011 | 08:55 AM
  #39
nath981's Avatar
i did.. we also have the humidity to deal with. the Sh should have 48#pilots jets for from the factory(98-00). not sure about the CA model or later ones, i am going to try the needle shim and see if i can barrow my buddies 90 deg driver to turn the air/fuel screws.
I believe the OEM slow jets are #45s.
It's up to you, but I wouldn't be dealing with the air screw for the first time w/o removing the carbs. Get em out, slot them or whatever you decide, then set them to 2.25 turns out. Find out what jets you have, change your pilots to #48s, shim needles & put it back together. Then if you want to fine tune, run engine and adjust with tool.
Don't hesitate to take the carbs out because with not having to remove the tank and the repetition of pulling them a couple times, it's pretty easy. Just takes a little patience and perseverance.
Old 01-21-2011 | 11:11 AM
  #40
The stock pilot jet size is #45 and it is listed on page 5-2 of your service manual.
Old 01-21-2011 | 11:27 AM
  #41
nath981's Avatar
took carbs off
my air/fuel screws were set at 2.5 and front was 3 turns out. (i had the d attachment for my old ratchet) mains are stock and pilot is 48, my manual said they were stock for my vin... ?? i shimmed the needles .040" and set the screw at 2.5,i may change my mind and turn them back a 1/4..
haven't got it back to gather yet. did not have to work today, glory of being self employed. (parts not in.)
That is weird that you have a #48 OEM and the air mix settings don't seem right for that Pilot jet and relative to bigger jet in rear and lower air setting.
I have a 98 also, and the honda manual says slow jet#45, front main #175, rear main #178.
And what i read somewhere is that to tell if you need a larger pilot, you back out the air screw till rpm drop, then screw it in a hair to restore rpm. Now if you back out air screw and rpm doesn't drop, you need a larger pilot jet.
Do your have a Honda manual, was your bike ca only model, european model or other, because #45 is standard set up AFAIK.
We need someone more knowledgeable than me to weigh in here cause i'm out of my realm of expertise, and that doesn't take much.haha
Old 01-21-2011 | 11:58 AM
  #42
The correct way to determine what size pilot jet to use is based on the setting of the fuel screw (it is not an "air" screw as it meters fuel not air)
If the bike runs best with thew screw set at 1 turn out or less, then you need to go down 1 size of pilot and try to adjust it again.
If it runs best with the screw turned out 3 or more turns, you need to go up 1 size.
Old 01-21-2011 | 12:25 PM
  #43
nath981's Avatar
oh, then the air mixture screw is determining how much fuel is metered to how much air is passing through?
So in R80gsman case, things are totally screwed up in that he has large pilots @#48, which means that his air mix settings should be less instead of more(closer to 2 than 3 turns out). what are yours set at?
On cars where the air screw was accessible, I just back it off till rpm drop and then go back a hair and it was good.
Old 01-21-2011 | 12:37 PM
  #44
Oh some carbs the screw meters air and on others it meters fuel. On a SH it meters fuel, that is why you turn it out to richen the mixture.
I can't tell you exactly what mine are set at. It is somewhere between
2 1\2 to 3 turns out with the rear turned out around 1\4 turn more than the front. So I think I'm at 21\2 in front and 2 3\4 on the rear but while fine tuning I just messed with them a bit till it was right but didn't seat them to find out exactly where they ended up at.
The proper way to set them on a bike is to turn the screw in until you get a 50rpm drop, turn it back out until you get the 50 rpm back and then open it another 1\2 turn.
Old 01-21-2011 | 12:48 PM
  #45
Both on how to setup the fuel screw and how to determine the size jet your bike should work best with... Both procedures are like 8541Hawk described, and both should give a decent baseline to work from...
The simple fact that most VTR owners will end up with 48's and between 2.25 to 2.75 turns on the screw is another matter... I still say it's a smart idea to do that on each bike, just to confirm...
And if you ask me what setup my bike has exactly my answer is along the same line as 8541Hawk's... Thumb and finger, so-so... Fine tuning isn't something I can put down in numbers, it's something I do "by ear"...
Old 01-21-2011 | 02:19 PM
  #46
nath981's Avatar
you guys are right,
after further investigation, they are 45# and the honda does say that the haynes does not.. the honda i have as a pdf and the haynes in the shop... that would explain the air/fuel screws.. not sure why the manuals are different... anyway, i left the the air/fuel(pilot) screw at 2.5 since it ran fine at 3 turns with a k&N and i am putting a stock filter in.. shimmed the needles .040" and putting the bike back together. as i had no 48# laying around.. maybe a later day, for that..
thanks for the help, just trying to establish a base line.. never tuned this bike.
it would be probably be much easier, less confusing, and make more sense if we had a SH baseline set-up for all of us who get in there for the first time. The numbers are already there, but you'd have to dig around extensively and then gather some kind of numerical consensus to figure it all out.
for instance, baseline for a superhawk desmogged with aftermarket exhaust or bafflectomey might include:
TPS 500 +- 10
pilot/slow jets #48
needles shimmed to .040in
pre-set air mix screws 2.25turns out(then adjust with bike idling accord to manual)
could resolve a lot of questions maybe...haha
Old 01-22-2011 | 04:11 PM
  #47
nath981's Avatar
got the stock like air-filter in and got the bike together and took her out.
shimmed needles .040", frt 2.5, r 2.75.
runs much stronger on the bottom & mid range and pulls better below 3k. still needs a bit of air/fuel screw adj. but the transition at idle to throttle is not abrupt.. still have some popping(muffled) not all the time. 48s may clean that up.
no real hiccups.
waiting for my new carb adj driver..
cheers
I have a similar set-up, OEM jets and Pilot, .040 shim.... however air mix @ 2.25 and no popping. Maybe you got air mix out too far out and if you're going to do the proportioning thing for front /rear, you might want to make it more accurate:like 2.50F 2.60R in lieu of 2.75, or better yet 2.25F and 2.30R. Evidently you aren't going to set the air mix while idling, so try my settings and see if that helps. Did you sync again after adjusting air mix?
Old 01-22-2011 | 04:26 PM
  #48
Ok now I'm damn confused by reading this......
First the screws control fuel (this is at least the third time I've stated this in this thread) so turning them in will lean it out and cause it to "pop" even more.
As for the 1\4 turn difference, that is what I use for a base line until it is fine tuned.
Setting the mixture at idle is the way it is supposed to be done, so I really don't get what you are saying there.
Old 01-22-2011 | 04:29 PM
  #49
no real hiccups.
cheers
Sounds like you are on the right track and opening the pilots up a bit more should cure the popping but then you are at the 3 turn setting, so yes the #48 would be a good idea.
Old 01-22-2011 | 04:35 PM
  #50
nath... Sorry, but sometimes you are just a little bit stubborn... But we still like ya...
The screws are for metering fuel... They have nothing to do with air... The closest they get is air/fuel mix... And like it has been said, they are leaner turned in...
As long as you keep thinking of them as airscrews you are going to get into trouble sorting this out in relation to each other...
The difference between cylinders are also individual, no fixed amount... The only constant is that the rear is set richer...
Old 01-22-2011 | 05:11 PM
  #51
nath981's Avatar
haha. I'm a bad boy and stupid too.
yeah I got the part, that they control fuel, but i didn't get the name change to pilot screws. They are not air mixture(where did i learn this? I believe it's been referenced by others before me.), they are pilot screws, ya hear me PILOT SCREWS!
Now my rationale for turning them in is that it also has been referenced herein(I believe I got it from Hawkrider). Anyway, the reason I suggested it was because 2.25 works well for me with #45 pilot jets, so if it works good for me, and his is popping, you see what i'm saying. Anyway, I am going to try #48s and set w engine running as soon as I figure out how to make a tool that works on my now slotted PILOT SCREWS(you like that don't you), and then pre and post sync the carbs.
Relative to the ratio of 173 is to 175 as 2.50 is to X, X would not be 2.75, but closer to 2.60. Now i realize that this is just a starting point for live setting, but for those of us who can't set while idling because of no tool or too lazy or stupid, you may as well put it closer to the same setting front and rear or just a hair more on the rear.
The strange part of it is in terms of my set up is that I have cut the flap and installed a foam filter which likely flows as much or more air than a K&N, yet it pops not and runs strong through the rpm range.
Anyway thanks for being so patient. PILOT SCREWS, no air no air no air no air. See I got it now.
Old 01-22-2011 | 05:15 PM
  #52
This would work with your slotted Pilot Screws......lol
http://www.motionpro.com/motorcycle/partno/08-0119/
Old 01-22-2011 | 05:25 PM
  #53
nath981's Avatar
A little bit stubborn. Just a little bit. thanks for the gentle appraisal. I'm one stubborn *****..........no doubt! and that's one of my best attributes. haha
Old 01-22-2011 | 05:33 PM
  #54
nath981's Avatar
but i have air screws. Thanks anyway though. haha
Old 01-22-2011 | 05:47 PM
  #55
nath981's Avatar
no real hiccups.
cheers
that's it, I've had it with you. Every time i try to help you, I get my *** reamed. haha
cheerio old chap!
Old 01-22-2011 | 07:39 PM
  #56
nath981's Avatar
if you want to little more info:
http://www.superhawk996.net/
then click on vtr1000, modificat, jetting.
and then click onto the Factory link
Old 01-22-2011 | 09:28 PM
  #57
Well this set up will work but once again the information I am passing along came directly from Dan Kyle. If you don't know who he is, well here is a quick blurb from his site: http://www.kyleusa.com/Home_Page.php
Founded November 10, 1997 by Dan Kyle, a master mechanic, who has built a reputation for blazingly fast and utterly reliable engines that have won 5 AMA National Roadracing Championships. Dan was crew chief and engine builder for the highly successful Erion Racing and Two Brothers Racing teams. He has prepared engines for riders Rich Oliver, Fred Merkel, Larry Pegram, Michael Barnes, Andrew Stroud, John Kocinski, and other champions. Dan has twice been awarded the AMA Tuner Of The Year.
So I'll just touch on a couple of quick points. If you want to believe the advice, fine. If you think it's wrong and want to go your own way, that is just fine also.
First, removing the restriction from the header. It is not a good idea. On back to back dyno runs the engine made less power with it removed.
Installing a jet kit. There really is no need. The factory needles are very good, they just need to be shimmed up a bit and make as much, if not more power, with a better curve than either the FactoryPro or DynoJet kits. The only needles the work any better are the HRC units but they are pretty much impossible to find anymore. The kit also has a couple of other tricks in it but hell I can't get you guys to believe this simple set up so why should I beat my head against the wall by trying to defend the other things that HRC did (and yes I run an HRC kit in my bike).
These setting are for a stock motor and if you make major modifications things will change but for the average member you can get as good if not better performance by installing $10 worth of pilot jets and a couple of washers instead of over $100 for a jet kit.
Old 01-22-2011 | 10:19 PM
  #58
nath, You're not stupid, but you may be suffering from a bout of "oldtimers". That can happen at our age.
The correct term in automotives is "idle air/fuel mixture screws", since they are used to adjust the idle air/fuel mixture. But since the last car with a carburetor (Hyundai Excel) was built in 1989, most auto techs today wouldn't even know that.
Old 01-22-2011 | 10:23 PM
  #59
agreed. that is the route i am taking, haven't the 48s yet but will get them. i like the 10$ over the 100$.
i have heard of Dan Kyle, he is a tuning magician, with race teams wins to prove it.
Believe it! The 48 pilots and the needle shim works great! I took Mikes advice on that 6 months ago. I went 2.5 out on the pilot screws, after trying 2.75, but that may vary with each bike and your altitude. Also, keep those carbs clean.
Old 01-23-2011 | 07:56 AM
  #60
nath981's Avatar
Is that compliment, consolation, or a combination thereof? If you keep the cup full, you can't learn anything because you already know it all. If you keep the cup half empty, there is always room for growth through learning. In my case, maybe the cup is leaking. If that's the case, it's just a matter of how fast and how long to ground zero. haha
