Manual vs. auto cct
#31
Yes, 2 mm+- is what i remember when I first looked at it when i took the valve cover off. I rotated the cam a tooth to see what it would be and was a big difference, if your a tooth off you'll see it really easy. With the new chains things lined up better.
#33
Yes, I did it. It was a little tedious but not too bad. I have air tools, an impact gun makes all the difference in the world for removing and installing the primary nuts on the clutch basket, primary gear, and flywheel. You'll need a flywheel puller too, basically a 22mm bolt. Change the water and oil pump chains while your in there. Engine ran the same, just dont hear the chain slap anymore.
