Man I wish this thing was fuel injected
I have no interest in modifying but the thing is, I live in Denver. If I were to jet it for this altitude, and ride it at sea level would it A) Damage the engine as conventional wisdom might suggest, or B) Not run properly? or both?
Or is it something you can just get away with since it's a Honda?
Mine runs fine up here on stock jets. Jetting is affective at low altitude because the bike is getting enough air that it runs a bit lean. Here in D-Town Lean will never be a problem. Stock jetting will make the hawk run a little rich up here which isnt a bad thing (unless you are lazy like me and havent dissabled the PAIR). Where in Denver do you live?
The mountain roads are ok. The ones you'd think would be awesome are covered in gravel and torn up from the chemicals they use during the winter.Plus It is a little scary when you come tearing around a corner to see a herd of elk right by the road.
I was actually gonna go up there this weekend glad you warned me. The guy I bought mine from got it at Sun. He didnt know that much about it. It wouldnt start when I bought it. it had 9k miles and had never been recked but since he couldnt start it i paid 2700 bucks! All it was was a fuse!
